Wiper Motor Swap
Old 12-31-2013, 01:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
If any of you guys with 51-52's could measure the dimples or holes, relative to the defroster screws, it would be a great help!
Old 12-31-2013, 03:54 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
I feel for you guys . Mine had the single vacuum wiper so I went with the dual cable drive system from Specialty Power Windows ( they make wiper systems too). They work great but drilling that second hole in the cowl was a little nerve wracking .
Old 12-31-2013, 04:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Then you know how I'll feel, if I have to drill two new holes, 3/8" away from the existing ones.... won't that look pretty?! Not like I'm going to try to weld them up with a full interior...
Old 12-31-2013, 06:06 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
On my 52 the inner vent screws are 8 1/8" apart. The screws for the wiper are 2" apart and the center line of them 1/8" behind the center line of the vent screws.
Old 12-31-2013, 06:24 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Ross, sent you an email.
Old 12-31-2013, 07:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Scott found his to be 1/4" back, Mike's are 1/8". Mine are real close to being on the same line as the defroster screws. That 1/4 or so is about what I'm lacking to bolt up the new unit. Thanks guys!
PS -- Mike, I love that color on the dash!
Old 12-31-2013, 07:33 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Hmmmm. I measured mine as well. I also got the 8 1/8" on the dimples. But I measured 1 15/16" on the wiper hole centers. Hard to get the measurement you're looking for Ross, but it's about 3/16".
Old 12-31-2013, 07:58 PM
firstrider's Avatar
firstrider
firstrider is offline
Here you are . Left is 2 1/2 " from defrost screw & the right is 3 3/4 " from defrost screw and 1/8 " lower than the screws .
Old 12-31-2013, 08:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Thanks Dennis!
Old 12-31-2013, 08:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That about splits the difference! I think I have a plan to use my existing holes. I also see that the DS wiper hole on mine is clearly towards the windshield more than the other. I'm guessing mine may have been a dealer installed electric system, which means the holes had to be drilled with the windshield in. That would force the drill to be angled, I'm guessing, pushing the holes forward in the dimples.
Thanks again guys!
Old 12-31-2013, 10:45 PM
Rokcrln's Avatar
Rokcrln
Rokcrln is offline
Now I have installed several Newport kits in different vehicles and they all needed a very small amount of tweaking but well worth it in every case. Now in my sons 51 F1 I installed their kit for replacement of the vacuum system and it bolted in and did not need the two center dash holes or any duct mods. I also used their delay switch kit and it all works great. No regrets and I look forward to my next Newport install.
Kevin
LFD Inc.
Old 01-01-2014, 03:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Here's how far off my holes were, to allow installation without putting the linkage out-of-plane. The stock unit can with operate out-of-plane linkage (it has ball joints at the pivots), the New Port cannot. Once I moved the holes in the mounting plate, it slid right up easier than the stock unit ever has. I can't explain why things are so out of kilter.... but I got tired of trying to understand it, and just fixed it. Note the holes in the dash weren't just wrong fore-aft, they were too far apart.
  #28
Old 01-01-2014, 03:13 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
That should do the trick Ross . So much better than grinding out slots and using big ugly washers .
  #29
Old 01-01-2014, 03:40 PM
Rimrock F1's Avatar
Rimrock F1
Good solution to the problem, nice work.
  #30
Old 01-03-2014, 03:36 PM
leonharu's Avatar
leonharu
leonharu is offline
Ross,did you say you tryed the factory electric wiper system (6V)?I have the vacuum motor now and I was thinking about upgrading to the electric unit.I have two of the 6V electric units now that works.I hate to dill the two dimples out in my dash though.I want to make sure it is worth while before I do this??
Quick Reply: Wiper Motor Swap
