Oil leak by the turbo questions
on
1 Post
That is the EBPV (exhaust back pressure valve) actuator rod. You can gut the rod and plunger out of the pedestal and tap the hole and plug it with a pipe plug. Unplugged the connector under the driver side of the turbo that activates the solenoid that lets the oil into that part of the pedestal, and either gut the flapper from the exhaust outlet on the turbo, or just tie it open.
diesel-fitter-bum01
07-08-2011 11:06 PM
yellow401
03-01-2006 11:10 PM
