F100 ignition switch
Old 12-16-2013, 11:08 AM
Rmc292's Avatar
Rmc292
Rmc292 is offline
I have a 1955 F100 and I need a new ignition switch I found a 1956 ignition switch but before I buy it I want to make sure it will fit into my 1955 dashboard. Can anyone tell me if the two are interchangeable?
Old 12-18-2013, 05:45 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Try posting this in the '48-56 F-100 & larger trucks forum.
I will also suggest that you may benefit from buying the HiPo parts catalog that is available on eBay.
Old 12-20-2013, 06:00 AM
The Horvaths
I looked them up. They were different part numbers. '53-55 used FAA-11572-A and '56 used B5A-11572-A. I suspect that the contact ratings -might- have been different. Somebody else can comment as to whether or not they fit and function anyway.
Old 12-22-2013, 10:10 PM
jonnireb's Avatar
jonnireb
jonnireb is offline
I have had a '56 switch in my '55 for several years. I don't remember if I
had to do a bit of minor hole enlargement or not. I know I did on some of the
dash fixtures, but none of it was difficult.
Old 01-07-2014, 08:01 AM
Bessie's Avatar
Bessie
Bessie is offline
Your asking about putting a 12volt switch into a 6volt system of the 55. Have you converted to 12volt? If not, go with a 53-55 switch - they are easy to find.
medino03
03-21-2014 11:18 AM
Nobby
01-19-2012 10:22 AM
Marky48170
11-26-2011 01:05 PM
scseth
06-27-2011 08:47 PM
Quick Reply: F100 ignition switch
