I6 on 35s gear help
I6 on 35s gear help
Just picked up a decent f150 300 strait six auto trans 2wd ext cab long bed very good condition very clean 150k miles for 1000$ I'm going to be lifting it and putting 35x12.5 under her , I drive about 50% highway and 50% town avg speed bout 50mph what's the best mpg rear end ratio for that ?
If it was my truck it would be getting 4.88s or 5.13s. 4.88s would put you right at where a truck with factory 4.10s and stock size tires would be
If your only cruising at 50 mph then you can get away with really deep gears without your cruising RPM climbing to high. You should only be running around 1600 RPM at 50 with 4.88s or 1700 with 5.13s.
427 fordman
15
07-30-2012 06:27 AM
shuttlevalve
04-05-2006 06:55 PM
