Borderbum's Diesel "Bandit"
#46
#47
Good Morning Everybody!
Jeff. This weekend would be better for me to head north. I have surgery on Monday to remove the cancer spot on my face and I don't think I'll be in any mood to root through a junk yard after that.
I have a trip to Monett today to get the parts I need for the GTO. Then I can get that disaster back together and see if it'll run. After that, I have 8 new cars to go through and get ready for sale.
The big news for the day is that the '49 is gone. I really wanted to keep it, but December is rough on a hotrod shop. No worries about the gasser, though. I decided to build one from scratch using a bantom body. I think it'll be cooler in the long run. Maybe when I'm rich and famous, I'll buy another '49 already done.
#48
#49
BANDIT is a Ranger or Ranger xlt cab,
Originally a 3 speed auto, now a 4 speed (he did tell me he switched this out.
3:54 gears
Dana 60 rear
Can't find the front exactly, it doesn't have a 1979 for the code
Medium Vaquero Metallic two tone with pastel sand
Interior was Ranger xlt lariat sand on vinyl
I looked up the color, not too cool.
3:54 gears
Dana 60 rear
#51
#52
#53
#54
[IMG][/IMG]
Highboy lift springs out of an fe truck. With the weight of the diesel, these will do the trick.
Hoping to keep the body lift at minimum.
Alan, thinking here, but these springs, a hydraboost brake system to make room on the drivers side, an I may look at those new air conditioning systems to make room on the passenger side....we might not need a body lift? If so we can go minimal?
Rich, what is the story on highboy springs? You can use the front, but the back are too narrow? The back highboy springs were about 2 inches wide....
#56
#58
#59
#60
[urlhttps://www.ford-trucks.com/forums/1215125-6-9-7-3-idi-into-76-f250-4x4-help.htmlhttp://www.oilburners.net/forums/showthread.php?20527-Late-70-s-Diesel-Conversion!-Pics-Inside-((((DIAL-UP-Warning))))]Late 70's Diesel Conversion! Pics Inside. ((((DIAL-UP Warning))))[/url]
http://www.oilburners.net/forums/sho...Cab-Conversion
https://www.ford-trucks.com/forums/6...-9-diesel.html 2wd tranny with divorced t case
Info on the diesel swap
Using a 2wd tranny with divorced trannsfer case
Even with the 3inch body lift it doesn't look like he has much space to take off valve covers....
