1995 E250 strange problem - transmission?
The first 111 is just a electrical check, then a space and then the code that would say why the computer is doing what it is doing. This code would be in CM.
I would suggest that you get another mechanic that understands your era of Ford van.
It does not sound like he even knows how to pull the codes on your van.
There is no way you would not have a code in CM unless you unhooked the battery.
I read somewhere back when my Speedometer went out that the PSOM could only compensate for 5 tire size changes, after that it went kaput. And I had gone thru about that many size changes when mine went south. I think if you change tire sizes, do all 4 wheels in the same size to keep from confusing the PSOM. I think this all has something to do with the 4 wheel ABS.
The PSOM only works with the tire sizes that are mounted on the rear axle. The 4 wheel ABS is unrelated to the PSOM in the 1995 E-series
The PSOM's Conversion Constant can only be reprogrammed six times. It is reprogrammed for tire size changes only and each time you reprogram the PSOM Conversion Constant the count is reduced by one.
If the PSOM is from a salvage yards cluster it may or may not have the right Conversion Constant in it.
Note that the rear anti-lock module can go bad and disrupt the signal from the VSS to the PSOM as it uses the same VSS generated information and is wired in parallel with the PSOM.
But the all same stuff still applies.
The PSOM is wired in parallel with the 4-wheel anti-lock brake system. The 4-wheel anti-lock brake module would have no effect on the PSOM unless it is loading down the VSS circuit.
Did you ever find the problem?
I have one from way back in the day.
I had quite a few vans with the E4OD (most often with the Diesels) giving us fits with various issues including erratic shifting.
What I followed the Pinpoint Test Step Procedures I came to a point where it told me the issue was in the wiring from one point to the other.
As it turns out the wiring harness under the passenger side battery seemed to collect acid vapors from the battery and did not show any signs at all on the wire clam shell cover, or even the internal plastic wire wrap, but when it is all uncovered, there were several wires swollen and bulging with that acid corrosion.
A faulty sensor code does not indicate a bad part if it is the signal that is getting interrupted ½ way to it's destination.
My 1996 E350/460 just this afternoon started doing exactly what you described on the freeway down shifting to a lower gear sounding like it was in neural, banging into gear, shifting rough.
I no longer have those pinpoint test step books, but will be pulling the battery and having a look see.
A 1990 does not have a PSOM.
If you have the E4OD then the speed information comes from the transmission/Xfer case to the PCM computer and then the computer controls the transmission.
If you have C6 then it is not controlled by the computer or the speed gear in the transmission/Xfer case.
They were for a 1995 and they change a little from year to year but the 1990 is not close at all to them.
My 96 E350 has the 460 with the E4OD and no speedo sensor, just a plug in the hole.
#28
My 1994 F53 460 E4OD has it in the brake housing on the drive shaft.
#29
I have no brakeparking brake assembly on the drive shaft like the older Superduty had (and as we called it the F450 as it had the rear disc brakes and was one step up from the F350).
If so, then my speedo bouncing issue at speeds above 45 mph might be coming from one of the rear wheels.
The parking brakes are also not working and the pedal goes way low on the first step when braking so I need to check them out anyway.
#30
