97 PSD Build Up!!! On A TIGHT Budget!
Correct, but you will probably be better off to call ahead, give them the VIN and make an appointment. They should have the part in stock but this way you don't have any surprises when you get there. It's possible too that it may have been performed already, but there should be a fusible link on the switch on the end of the brake master cylinder and it generally has a big Ford blue tag on it. I don't see that in your pictures, so I'm assuming it hasn't been done.
Haha i sure dont! Im going to buy a new downpipe from diamond. It seems that the stock downpipe and muffler unbolts and the new one is a two peice and bolts right on, it looks like it will fit perfectly because right after the bolt is my d-celerator unit. Do you know anything about that?
You don't want a 4" down pipe, trust me....
Substantial changes to the firewall have to be made to fit a 4" DP. You will have a hard enough time getting a 3" in there and there are plenty of 500-600 horsepower truck using the 3" downpipe. 4" isn't necessary. Just to clear the 3" you will have to cut the pinch weld in several places, then bend it back flat against the firewall. To clear a 4" you really ahve to get aggressive and butcher it up bad (think cutting out sections and building a new tunneled out section of firewall). It's a big project that will require either having the engine out of removing the dash. 3" is doable and is all you'll ever need.
And for the decellerator and PAC brake, keep in mind you could always remove them and sell them for some "build money" if you don't intend to tow or haul heavy.
Ok good,someone said to get 4in, but a 3in will be just fine, and with it straight piped it will give me great sound. Im going to order the diamond 3in aluminum dp, and the riffraff 6637 kit for my first mods. And haha this truck has so much stuff im still trying to figure them all out. It has a built tranny with a gear vendors, so looked it up to see what its all about, it was a $3000 system!!!
#28
