Exhaust manifold tap size??
I had to take the exhaust/intake manifolds off to replace the gasket due to it falling apart. When I took it off the block I could scrape all the old gasket off the block fairly easily, but the manifolds were not so easy.
So I decided to take the manifolds all the way out so I could scrape them clean. In the process of doing so one of the bolts for the exhaust pipe connection broke flush. Not too surprising. The other side was a stud and I had to burn the nut off with a torch.
Now I have extracted the broken bolt out of the manifold, and went to clean up the threads with ta tap, and here's the problem.
The threads are 7/16-14, but after cleaning them up the new bolt wiggles loosely in the hole.
Is this something to worry about?
Should I drill and tap it to 1/2-13??
Can I just use heat resistant loc-tite instead of re-tapping larger?
Thanks!
Thanks!
powersmoked
1983 - 2012 Ranger & B-Series
04-16-2012 03:27 PM
ford351powr
02-21-2011 11:39 AM
MikeS29
22
07-19-2010 09:01 AM
stangfan78
07-23-2007 05:12 PM
