Let's see those aftermarket exterior lighting set-ups!!
#196
KC mounted on a Sleekster Bar. Two outside lights are wide beam for the bush and the two centres are beam. The bar went onto 4 existing bumper mounting bolts.Used the #1 and # 2 Upfitter locations. Run them lots on my road of 70 kms one way...a couple of times a week with lots of critters. BTW, the way I read the Ontario law was not the # of lights but the amount of candlepower. The aux lights cannot exceed the factory wattage if you run them on a road. Oh yeah, it is up to the cop if you get the ticket, but when not in use they have to be covered.
Sorry but I couldn't see how to make this pic smaller.....
#198
#199
Pods are less likely to draw unwanted attention. There are DOT legal options from Rigid now.
#200
#201
#203
I like this setup!! Don't the LED light bars have heat sinks from the heat?
Do you have a night photo of this? I just picked up a Westin HDX brush guard so the grille on that would actually not allow me do do this setup but I am looking into mounting LED light bars directly into the grill on that brush guard!
#204
So your marker light is covered (except for the state logo)? What about turn signal, does any of that need to work? Do you have information on the light you installed?
Not sure if this counts since it's technically just a modification of existing lights. I took the headlights apart and added some led tubes to accent the light then I painted the inside of the light to match my Ex's color and added a Texas shape on the side running light to coincide with the South Texas Edition billet badges I had made for my front end conversion. I put a led for the blinker, a Hid for the headlight and then switched the fogs to led.
#205
#206
Sorry... a bit off subject but, TrailWhale, what winch setup is that and how did you mount it? I have a 2015 and don't feel like buying a winch bumper - that looks great (almost like a factory option)!
Thanks - Jim D
