Let's see those aftermarket exterior lighting set-ups!!
And they'll custom make them for you, too!!
That is the same style Contura that I have for my overhead console, by far the best looking switch on the market! I am just now getting around to getting all the cool stuff that they will power, lol!!!
I have a thread on here about the console build and I have six of those switches.
KC 6x9 HIDs with driving beam lens, M4Products 30" LED bar in combo, and KC 5x7 100w with driving lens in the OEM fog locations. Upper lights are mounted to a bar found currently on EBAY. Bar lights are fed from the up-fitter switches, fogs are fed thru their own harness relay switched with the OEM Head/Fog switch. I run them due to the wildlife around my area. It's cheaper to buy lights then keep replacing the front end. FWIW the HID outshine my LED by far. It might be related to the height placement of either. I like it, it works for me.
Lighted running boards and under hood lights using LED light strips. You can read about doing this in detail in the following thread. https://www.ford-trucks.com/forums/1...-time-out.html
http://www.ebay.com/itm/48-SMD-3528-LED-Dome-Door-Box-Light-Panel-Interior-Bulb-T10-Adapter-white-12V/310710839074?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D2826919091005268296%26pid%3D100011%26prg%3D1005%26rk%3D1%26rkt%3D5%26sd%3D390552076760%26
Then what I did with the LED panel that came with it, I put it inside my slide in truck camper. I hooked up to a magnetic switch mounted at the door so when I open the door to the camper, the light comes on automatically, sure beats having to fumble for light switches in the dark.
Did you have OEM fogs in the bumper already?
First pic is great, love the perspective!! Looks like the light thrown onto the ground shows the LED bar to be more of the beam style while the two square lights have a wider spread? Is that accurate?
The leds in the middle of the bar are driving lights and the ones on each end are spot\flood lights(On the bar).The D2's are driving lights.
How did you mount the middle bar (20" or 14"?) to your bumper? Do you think the D2's could be mounted under it if there was no license plate? Also i have a bull bar do you think that would cut off the light significantly? I'm trying to come up with mounting idea's before i get some led bars lol.
#28
#29
