Power steering in 750 and larger?
Well I can tell you that the T950 that I recently purchased came standard with power steering so I have to assume the parts are out there to convert yours. The C600 that I also have also has power steering.
So parts should be readily available.
I probably should add that most of the larger truck models also had optional what was called a center point steering axle, these did not have power steering as the steering geometry was designed such that the steering was easier than with the standard steering setup.
David
David
