carrier bearing replacement question
I'm replacing a carrier bearing on my 2002 F-350 CC LB. I took the front part of the driveshaft off. it just slipped apart when i unbolted the bearing bracket and now I pull off the rubber for the bearing and I'm stumped. The flange at the bottom seems to be solid with. and the bearing is in between there loose as can be. Any help would be appreciated.
Rasputin53
02-13-2017 12:44 AM
Funke1
17
09-30-2014 02:28 PM
