Newbie with PSOM and OD questions
Hello Everyone!
92 Ford F150 Custom, 5.8, Auto, 4x4, 155,000 miles
I started out trying to research a fairly simple question and ran across your forum. Reading through the threads, one thing lead to another! I'd like to be an active member and offer my insights when appropriate.
My 2 questions:
The button for Overdrive is on the steering column, I know it's functioning because when I press the button, the RPM's change (don't know how much, no tach). Is there a light that should display when the overdrive is on or off? If so, how do I change that light?
Second, while researching the OD issue, I saw threads about the PSOM. I changed my tire size from 235/75/15 to 245/75/16. I have been looking but I can't find a "conversion constant" to make the change. Anyone have any helpful direction?
Thanks for the help!
Tom
My 2 questions:
Tom
Welcome to the forum!
I don't know about the overdrive button issue-I drive a manual.
But the following article should answer your question about reprogramming the PSOM:
HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles
I prefer this info posted by Steve83: 1983 Ford Bronco PSOM picture | SuperMotors.net
Don't get a screwdriver anywhere near those old plastic parts, things will break off. You can get a button replacement for very cheap, mine cost about $9 for a OEM part not so long ago. Just pull out the plastic ring from the top of the lever, then slide the tab, then pull the button out, the assembly is the exact opposite of this.
Thoth88
08-08-2017 05:42 AM
blackwidowrealtree
13
02-06-2015 07:17 PM
HVJ
12-20-2004 02:40 AM
