HI GUYS, I HAVE A 1991 FORD F150 WITH A BAD 5.0 LITER ENGINE. FOUND A 1993 FORD F150 5.0 LITER ENGINE IN GOOD SHAPE. WILL THIS ENGINE SWAP INTO THE 1991 FORD WITH NO PROBLEMS? THANKS.
Yes, but don't use any wiring that comes with the donor, don't use the flywheel that comes with it, and use the distributor that's from your '91 but put the drive gear from the '93 on it first.
