New to Powerstroke
#302
^^^^ Yep. The '83-'86 and '87-'91 trucks had an issue with the firewall flexing (and in extreme cases, cracking) from clutch pedal action on the master cylinder. Ford offered a reinforcement plate to remedy/prevent it, and there's presently a guy making one of his own design, that's even beefier than the Ford reinforcement. The firewall was redesigned for '92 (OBS) to eliminate the problem.
#303
Well, since my 2006 Tundra decided to take a dump, I've had to daily drive the Ford. Sad that a 96 is more reliable and gets better mileage...but I have found that it does in fact need new glow plugs. It's been in the teens (here in Georgia that's cold) and it just would not start without having to be jumped off. So I started plugging it in and it starts almost instantly. Do you guys have any recommendations for glow plugs/glow plug kits? And two things that need to be replaced are the headlights because they suck, and it needs a new shifter boot and the plastic piece that holds it down. Any suggestions? For headlights, do they make HIDs or anything that provide way better lighting? Thanks guys! Also might be picking up an 02 f250 with 205,000 miles and one scratch if my tundra is done
#304
#306
#307
#308
#309
yup. That's how mine was. my wife's pretty supportive. Her answer was you may as well do it now. My answer good thinking honey lol. It's all about making her think she thought of it lol.
#311
#313
#314
So I'm pretty sure I found the culprit for my annoying sounding transmission. I found the throwout bearing sitting in the truck, brand new in the box...my guess is that when I told the guy I was getting the cops involved, he threw it back together and forgot to put that in. How hard of a job is that to do? I have a 3 ton jack, but is it basically just drain fluid, unbolt, lower down with jack, install throwout bearing, and jack up and rebolt?
#315
Well, I suppose that would do it! He must have left the old one in there (hopefully).
You don't even need to drain the transmission, it's more or less just a matter of unbolting things, dropping it down and then putting it all back together.
The biggest thing is to be sure when you pull the slave cylinder off the clutch fork that you fasten the rod in there, or it will push the rod out, dump the fluid and then you're stuck with a real headache of trying to bleed everything with it in the truck. There are several different home made tools that guys have come up with to accomplish this.
I'm not going to tell you it's a small job, but it's not difficult.
Just be careful. That transmission and transfer case are heavy. I'd separate them and drop them individually if it were me doing it and I didn't have a transmission jack.
