Michigan Chapter Join Chapter, Leader: Toyman
Scratch it... New plan
Old 10-31-2013, 09:36 PM
Fordman96's Avatar
Fordman96
Fordman96 is offline
I have been talked out of a diesel (for this swap anyway.)
Now I'm going to build up a gasser for my 96 bronco.
And there is 2 different routes I can go (both ways will have a manual trans.)
1: my 351w to a 408w (already have it priced out) possibly super charge?
2: a good friend of mine has 2 351M/400s out of a 79 bronco that are mine for the taking. So I can pick them up for free (go carb instead of MAF) and build that up?
What I'm looking for:
Under $3500-$4000 for the engine build (not including forced induction)
Around 350-400rwhp with good torque
Reliable!
It's gunna be 50/50 toy/daily driver so I don't wanna go overboard with the build
Old 10-31-2013, 10:33 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Well a good 12 valve Cummins would be the ticket but then you're gonna need a good trans and there goes your budget.
Old 11-01-2013, 07:09 AM
4.9L's Avatar
4.9L
4.9L is offline
Are you looking to stay with a ford power train? That 12v would be a badass swap
Old 11-01-2013, 09:53 AM
Fordman96's Avatar
Fordman96
Ya the whole reason behind going with the 7.3 was to stay with a ford power train. I know the 4/6bt cummins are popular swaps because they are around 150lbs heavier then my 351 but have much more torque.
Maybe on the next one I'll do a diesel swap but for now I'm just going to go with a gasser. I don't drive the truck hardly so time really isn't much of an issue for now.
The only down side is that with winter moving in and colder temperatures it gets harder to work on the truck since we don't have any kind of garage/pole barn and my buddies are busy fixing there Chevy's for the spring.
Old 11-01-2013, 08:26 PM
Fordman96's Avatar
Fordman96
Engine list:
Edelbrock Performer RPMs Aluminum Heads 170cc ported and double spring with PRW aluminum 1.6 roller rockers
- $1000
http://detroit.craigslist.org/mcb/pts/3623533032.html (heads. $1000)
http://www.summitracing.com/parts/cca-35-320-8 (camshaft. $300)
http://www.summitracing.com/parts/tf...1004/overview/ (intake. $700)
http://www.summitracing.com/parts/bb...view/make/ford (Throttle body. $210)
Probe SRS Forged Pistons 12355-030 - SummitRacing.com (Probe pistons. $443.)
Federal Mogul Engine Re-Ring Kits K2056116M311 - SummitRacing.com (re-ring kit. $195)
http://www.summitracing.com/parts/kn...d/model/bronco (Cold air intake. $215)
http://www.summitracing.com/parts/ms...view/make/ford (distributor. $276)
Old 11-01-2013, 09:26 PM
4.9L's Avatar
4.9L
4.9L is offline
Either way it sounds like a nasty built
Ford3+
General Diesel Discussion
12-24-2015 10:27 AM
mater73
1978 - 1996 Big Bronco
17
04-12-2013 10:54 PM
ZmanAK2005
02-08-2013 11:21 AM
Aussie_F_trucker
03-10-2012 02:29 PM
Eddiestruck
28
05-17-2009 11:12 PM
Quick Reply: Scratch it... New plan
