Exhaust
Old 07-17-2003, 02:06 AM
F1 Ford's Avatar
F1 Ford
F1 Ford is offline
Exhaust
I installed a Flowmaster single 3" (force 2 I think) on my last truck, the install was gravy, as stated before getting the old crusty stuff off is always the hard part. It sounded muscular but was not at all overbearing and best of all it was still in fine shape after 7 years of service. I'd highly recomend the Flowmaster catback, especially the 3" single with 3 chamber muffler.
Old 11-19-2005, 02:52 PM
nyironbiker's Avatar
nyironbiker
nyironbiker is offline
I'm looking for the cheapest place to order my flowmaster for my 04 f 150 5.4l
any help?
Old 11-19-2005, 11:54 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,740 Likes on 1,330 Posts
any help?
Cheapest place I have found yet:
http://www.performance-curve.com/ind...TS&Category=14
Old 11-20-2005, 10:58 PM
GammaDriver's Avatar
GammaDriver
GammaDriver is offline
Some may not like this, as it doesn't lead to jumping on the Flowmaster bandwagon, but from the research I did before buying I was informed that the Dynomax is what you'd want based on your original performance criteria. It seems Flowmaster sells for its sound, but the Dynomax mufflers generally outflow them by at least 100 cfm.
My advice is for you to call Summit racing and speak to their tech guys. These guys have the stats for everything (as Summit's main focus is performance for racing), and are 99% of the time more than willing to spend the time it takes to get your vehicle set-up correctly (if you are going for performance). I ended up with a single exhaust with a higher-flow muffler (compared to the Flowmasters). The single exhaust maintains the scavenging effect needed for performance, and overall it is less weight than a Flowmaster dual system (which isn't a true dual anyways... i guess it is more for show and sound?).
My goal was better fuel economy, which I think I achieved. In the end the truck sounds great, too.
Like pantherpics's experience, I used an angle-grinder with a cutting wheel to make a slit or two on the outside pipe under the cab of the truck. I used the same wheel to cut the rusted u-bolt nuts off, too.
captcalvo
01-02-2006 12:02 PM
msanders
1997-2006 Expedition & Navigator
02-25-2005 03:26 PM
Mikeleew
12-28-2004 01:59 PM
1969f100
02-19-2003 11:23 PM
Quick Reply: Exhaust
