Offroad & 4x4
offroad & 4x4 b/s thread
Old 10-29-2013, 10:39 AM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
The carrier adjustment make it very easy but the principles are the same as a dana. I'd regear Dana's any day of the week, blindfolded and one hand behind my back over Pauls Sterling. That thing made me cuss....a lot. If it wasn't so heavy I would've thrown it out the shop
  #92
Old 10-29-2013, 10:44 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
What was so bad about that sterling compared to a Dana?
  #93
Old 10-29-2013, 11:00 AM
alpha/omega
The initial setup was wrong so I had no baseline to start making adjustments. It also had no pinion shims or crush sleeve in it what so ever. Then when I finally get it set somewhat close I see the runout on the ring gear was like .005" causing loose and tight spots. This is after i found the pinion splines were cut wrong.
I guess a majority of my complaint is with a crappy set of Motive gears (returned them to Summit for a set of G2s) and not having a good place to start as a baseline.
Aside from that its a pita to get the really thin shims sandwiched between a thicker shim and then everything slide in easily and together. A majority of that problem was not taking the time to build a beefier housing spreader.
I like pressing the bearing on top of the shims and knowing nothing is going to move and everything is seated.
  #94
Old 10-29-2013, 11:30 AM
hav24wheel's Avatar
hav24wheel
I could have swarn I mentioned I'd send you some better shims. The carrier shims I have, have hold all the shims together in a sandwich so it's like putting in one thick shim. Had a extra set
Like these
Ford 10.25" Carrier Super Shims
  #95
Old 10-29-2013, 11:43 AM
alpha/omega
You did. I didn't know they were different than the regular shims I got with the rebuild kit.
That's pretty slick!
  #96
Old 10-29-2013, 12:45 PM
hav24wheel's Avatar
hav24wheel
The ones in my 10.5 are a bit nicer then the ones in the link. And the ones that came in my install kit I got are like the ones in the link. Than I have a stack of regular old shims like you used. Them do suck.
  #97
Old 10-29-2013, 05:45 PM
77mud's Avatar
77mud
77mud is offline
The 9" is easy to setup to me, I like the fact you set it up on a bench rather than laying under it
  #98
Old 10-29-2013, 08:20 PM
alpha/omega
I set Dana's and Sterlings up on a bench.
  #99
Old 10-29-2013, 08:27 PM
kjett's Avatar
kjett
kjett is offline
Me too. It's not that hard to pull the whole axle out and beats laying on the ground
  #100
Old 10-30-2013, 07:16 AM
alpha/omega
Its not hard as long as you keep your finger bones in one piece instead of multiple.
  #101
Old 10-30-2013, 12:15 PM
captain p4's Avatar
captain p4
captain p4 is offline
#my bad
#GMB hurts everyone that touches it
  #102
Old 10-30-2013, 12:29 PM
alpha/omega
I didnt know you had nerves in your wallet
  #103
Old 10-30-2013, 02:05 PM
joe f350's Avatar
joe f350
joe f350 is offline
dont worry kris when i win the super latto i will ship u my f350 to you to re gear and rewire and rebuild lol
  #104
Old 10-30-2013, 02:46 PM
alpha/omega
Leave a box of Diesels in the glove box.....
  #105
Old 10-30-2013, 02:53 PM
captain p4's Avatar
captain p4
#should start working on own truck
#works on everyone else's junk
#FTE thinks I can't turn a wrench
#sadpanda
Quick Reply: offroad & 4x4 b/s thread
