2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
C1726 2007 Expedition
Old 10-24-2013, 04:00 PM
Lowe's Avatar
Lowe
Lowe is offline
I am getting the code C1726 (Air Suspension Rear Pneumatic Failure)-- I have done various trouble shooting. Neither of the Two Leveling devices are bad. I have removed the Airlines from each bag and with a bit of running back and forth to turn the key on and off and close the door I have inflated both with external air and neither seem to have leaks. I have uncoupled the leveling arms and confirmed the control module does recognize vehicle height and it demand the pump at various positions. I blow a little pressure (10-20psi) in to the vehicle air line and it appears to hold but when I apply suction it doesn't. Anyone have any experience with typical failures on these systems? I suspect the compressor is bad and unable to build pressure as I can hold my finger over the hose when the compressor is running. Any feedback is appreciated!!
Lowe
Old 10-25-2013, 02:12 PM
Lowe's Avatar
Lowe
Lowe is offline
Update:
after monkeying around with it most of yesterday I have finally determined its the compressor. I manually inflated both bags and disconnected the solenoids at each air-bag just to be sure I didn't have a bag leaking. As of now both bags are completely inflated with no change in vehicle level. New compressor to arrive Wednesday Oct 30th and will be installed shortly after.
Lowe
MorrisClan
1997-2006 Expedition & Navigator
05-02-2020 10:03 AM
Sledmamma
01-03-2012 05:42 PM
mudder1_2000
25
05-10-2011 02:24 AM
Vigilant32
1999 to 2016 Super Duty
01-18-2011 02:58 PM
Quick Reply: C1726 2007 Expedition
