Question about rear ends (automotive) ;-)
My 56 has the rearend out of a 56 mercury car (not sure which), the bolt pattern is 5x5. I want to end up with a 5x4.5 pattern to match the front. I don't want to use wheel adapters so I'm wondering what the best option would be. I don't think the rears from later model f100's had 4.5 bolt patterns so I'm assuming I'm going to need something from a car correct? Is it possible to just swap axles or something?
I had the same issue, and had a machine shop re-drill the axle flanges and brake drums for the new pattern in between the original stud holes. i also had them install new studs in the new holes. You have to have this done by a machine shop to keep all dimensions correct to prevent vibrations. I have ran my truck on a chassis dino up to 130 mph afterward with no vibrations.
yeah that's another idea, may end up going that route. Search function gives way too many non related results and I got tired of clicking through them.
This article has information you are looking for:
1953 - 1956 F100 Rear End Selection and Rear Suspension Lowering .: Articles
cudaboy68
01-18-2015 03:32 PM
medicpg
24
12-07-2008 05:51 PM
medicpg
03-31-2008 12:52 PM
