Mirror swap question 92-96 mirrors
I've seen several pics of dents with 92-96 F-150 sport style mirrors. I've done quite a bit of surfing and searching, and i still have a few questions. I was wondering what everybody did with the inner brace on them. Do they bolt to the inside of the doors like the newer trucks do? Do you just let them hang? Or do you cut the brace off and just mount them with the two bolts? My main concern is if the brace does not mount, will the door be too weak to support the mirror and warp out? My mirrors are coming tomorrow so it'd be great get some insight on the best way to mount them so I can get the mock up and fit on that done, and finish the body work on the doors.
You should drill a hole under the door panel for the brace mounted to the mirrors. They won't quite reach so you'll have to run a long bolt with some spacers. Without it they'll flop around as they are heavy. I looked into it but did not like how they run slightly up hill. Going to go with ranger mirrors myself.
You definitely want to keep the brace. You can buy a longer bolt for the brace and space it with washers or nuts between the inner door skin and the brace. I bolted mine directly up and it looks okay, but changed the angle of the mirror slightly. Not enough to make me want to change it, but YMMV.
Here's a pic of mine:
You could thread a stud into the brace, mount the mirror up from the outside, unscrew the stud inside the door until it touches the inner door panel, have someone hold the mirror outside and give the inner door panel a little whack with a hammer, the stud should leave a mark, center punch that and drill!
That's what I would do...
Thanks, and thanks for the help.
