1972 F350 problems, need help
I have a 72 F350 with a 360 FE. On my way home it started running real bad when a started off from a red light. Its back firing and loosening power. I drove it on home and it would smooth out some if you pressed the pedal all the way to the floor for a min or two. I've checked all the basic stuff. Plugs, wires ,and points. Coil I even put a vacuum gauge on it and it checked perfect... I'm at a loss, I Dont know what else to check.... I also checked the gas to make sure there was no water/ trash. Looked good... and it has a brand new carb on it also.... anyone can help it would be great
Check battery voltage and alternator output. New alternator could be bad and truck running out of battery power.
Good Luck.
Well, off idle we need more timing and more fuel.
Timing:
1.check vacuum advance to be good
2.check Dizzy points breaker plate to not be tilted and pivot smooth
3.if still points,check dwell to be 30 degrees at idle. Then try to rev it and see if dwell changes more than 2 degrees when it starts to fall on it's face.
4. for giggles you might change the condensor. They are cheap.
FUEL:
1.Check fuel pump to have about 5-6 pounds of pressure if mechanical.
2.check to see if a rubber vacuum nipple cap came off a venturi vacuum port nipple on the carb. (vacuum leak off idle)
Timing:
FUEL:
19-F250-78
12-15-2014 09:45 PM
FordPower2038
12-08-2014 07:15 PM
semocoachworks
07-15-2012 11:02 AM
59'er F100
05-18-2007 03:57 PM
packrat56
05-29-2004 12:34 AM
