Brake Pads and Rotors
I had about 80k on my original pads and rotors on my '06 when I changed the pads. Rotor surfaces were still in good shape. Based on that experience, I didn't have to ask what pads to replace them with. OEM baby!!! And I specified brown box OEM, not Motorcraft equivalent. I'll let you know in another 60k how well that worked out for me.
pads stuck in bracket
I just had the oil and fuel maintenance done and the tech told me my brakes are shot...2008 and 35k miles!! The backing plates on the pads are rusted to the point of disintegration. I decided to try the brake job myself because I don't want the same crap that Ford put on at the factory. I'm no amateur, I've done many GM truck brakes over the years. I got the caliper off and the pads wouldn't come. Ok...The bracket is now off and the pads are rusted tight. I presume that they come out the back of the bracket (away from the rotor)... Any ideas on how to get the pads out, short of a torch?
As always, thanks and regards...and sorry if I high-jacked this thread...
on
Sorry I missed that part, you can usually get them out with some persuasion. I just got some new pads today and got them in. They were for the rear and they were from O'reillys and $21 for all 4 rear pads and powdercoated so they won't do what yours did.
Making progress!
Thanks again. Iput one side back together today with anti-seize and brake lube so the next time it might be easier. It's taking me a while becasue i get to work on it in 20-30 minute increments and I am figuring it out as I go. The other three wheels will go much faster. Are the rear brakes significantly different ? Thanks again...joe
OBTW: the original setup and the new pads have a small insert that goes between the retainer/anti rattle and the bracket. What is that thing? Some other replacement pad sets don't have it. There is only one per wheel.
on
