Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F800 Tilt Hood Insulation?
Old 10-09-2013, 09:13 PM
Pete Kildow's Avatar
Pete Kildow
Pete Kildow is offline
Anyone have a good ideal how to put new Sound Deadening or Insulation on the F800 Tilt hoods? Mine only had one piece left and it fell out. Thinking I have 2 of the springs that hold it in.
Insulator-Hood-W/tilt front end 1984/B-F 600/900 Part 16738 3 pieces of the 16775, 8 of the 385098-S (SS-47-B), 8 of the 388930-S (NN-180-G)
But thinking I will have to use use something to make this stuff and do the best I can to replace it.
Pete
Old 10-10-2013, 05:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Insulator-Hood-W/tilt front end 1984/B-F 600/900 Part 16738; 3 pieces of the 16775; 8 of the 385098-S (SS-47-B); 8 of the 388930-S (NN-180-G)
Scroll down to lower pic.
1) E4HZ-16738-A .. Hood Insulator w/tilt front end.
2) E6HZ-16775-A .. Outer Hood Insulator Retainer
2) E6HZ-16775-B .. Inner Hood Insulator Retainer
8) 385098-S .. Hood Insulator Clip / Obsolete
8) 388930-S .. Hood Insulator Clip
I didn't look to see if the other parts are available or obsolete.
Numbers in parentheses are the standard (hardware) parts bin (used at dealers) locator numbers only.
Old 10-10-2013, 08:10 AM
Pete Kildow
Bill Found the second and Third parts at www.finditparts.combut they did not show the blanket its self. But thinking I found something this am that will work to replace it. DEI 050130 Boom Mat Under Hood Thermal Acoustic Lining
So may try out this lining to see if it will do the job. New Muffler was put on Monday, and does its job well. Exhaust sound is nice now, but does not drive you crazy with the loud Sounds. But the motor is the loud part now. db's dropped down 9 db's and love it now. When the motor noise and new rubber on all doors and windows. Thinking the old truck will be quite as one can expect it to be then.
Old 10-12-2013, 09:12 AM
NumberDummy
E4HZ-16738-A .. Hood Insulator w/tilt front end / Obsolete
No Ford dealer or obsolete parts vendor has any.
Do you need the plastic 'push-in' clips?
Old 10-12-2013, 09:41 AM
Pete Kildow
Bill I think with what I have and the junk yard. We will be able to get all the items but the blanket. Thinking the one I here http://www.designengineering.com/cat...coustic-lining Found it one spot for around $60 per pack and figure it will take 1 of the 12 sq ft kits to do the hood and dog house right.
Also Heavy Duty Truck Parts Online, Medium Duty, Light Duty - FinditParts shows most of the smaller items are in stock.
Pete
Old 11-01-2013, 08:22 PM
Pete Kildow
Bill need more info.
Theres a hose on my Radator pass side at the top off the tank. It comes out toward the motor then turns to the pass side then turns down along the side. When it gets toward the bottom it turns back to the motor and looks like it may T into the bottom hose? Can you get a part number for this hose? Need to get it and the bottom hose along with any other hose other then the Top hose. I have it new and will be replacing all the other Hose's including heater hoses within the next week or so.
Any help tracking down this odd hose will sure help. If I have to will use normal hose that size and find metal elbo's to make the bends with. That or have a SS flex hose made up.
SeaCarr
WTB - Parts & other
03-21-2016 10:29 PM
lowbrow88
08-04-2013 01:38 PM
chriscris
WTB - Parts & other
10-20-2011 11:00 AM
rockher_man
09-16-2010 08:34 AM
bigd45
11-23-2009 11:01 AM
Quick Reply: F800 Tilt Hood Insulation?
