1996 Ford powerstroke. History of problem, started idled fine, backed up started running extremely rough and dies. Restarted all was fine, drove 3 blocks and engine started running very rough and barely made it back home.
It will start fine, runs 3-5 seconds, than starts idling extremely rough,engine light comes on and it then dies. Replaced cps, checked fuel filter and ran scan, no codes. Any ideas what'a wrong?
I can sometimes keep the truck running by pumping the throttle, however, its very difficult!
Could I have a faulty ICP, can I test by unplugging? Thanks!
Unplugged the ICP connector, still runs rough and dies. Scanned, it picked up the fault, cleared fault and started again, no fault recorded. Checked oil in HPOP, its fine. Looks like it might be the IPR? Your thoughts?
