Tight engine after re-ring 302
Old 10-01-2013, 10:35 PM
bullmoose11's Avatar
bullmoose11
bullmoose11 is offline
Tried to turn the engine over today it was really tight, so tight using a torque wrench on the crank nut was past the 85 ft Lb click. and we really had to muscle it. The starter bogs down and barely will turn it with the plugs in.
during reassembly The engine turned as expected as each cylinder with new rings was put in. After all eight were in still wasnt that tight. so tight you couldn't turn it with a 1/2 in ratchet. Placed the 289 HIPO heads shaved .010 50 cc chambers and adjusted the lifters on to a new Comps 31-218-2 cam (268 dur .456 lift). The turn got a little stiffer.
I'm re-using the old main bearings and rod bearings as the engine was a previous reman and plasiguage said .003 all the bearing surfaces were cleaned up with crocus cloth. Each piston was numbered and rod numbered and placed in the same hole and same orientation.
After it sat for a few days is when I noticed it was tight while still in the engine stand no tranny attached. I squirted some Royal Purple break in oil in each cylinder. I didnt notice too much improvement.
The only thing I can think of is the rear main seal may have moved and is binding, or could it be, Comps Cams said new springs are required for this cam but since the lift is below .500, the stock springs should be ok is my thinking.
The springs don't seem to be overly squashed. I'm supposed to see 1/8 inch of daylight in the spring when fully compressed Right? I'll recheck each spring clearance tomorrow.
What else should I try? I have taken out the plugs and that helps a little.
I plan to pull the plugs loosen the lifters try and turn the engine from the Harmonic Balancer nut. If it does not improve the friction what else should I try?
Could it be the rear main seal? I would hate to pull the engine and tranny again and do a teardown.
Old 10-02-2013, 10:22 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
Was the block machined? Did you check cylinders for round? Could it be possible the cylinders became tapered? Once the new rings were installed into out of round cylinders causing excessive drag. Don't know just throwing out ideas...
Old 10-02-2013, 10:51 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,643 Likes on 1,340 Posts
End gap on rings checked?
Old 10-03-2013, 10:46 AM
crazy96863's Avatar
crazy96863
crazy96863 is offline
Here is a wild guess... But it comes from a personal experience.
You mentioned everything was good until putting the top end on. I suggest you check the lifter retainer tray bolts... I inadvertently switched them with the cam thrust plate bolts; same thread type but the cam thrust plate bolts are slightly longer due to an unthreaded tip. The longer bolts were pressing on the #2 & 4 cam bearings.
If this is it, the best fix is new cam bearings. You can always try simply replacing the bolts to see how it feels but keep an eye on your oil pressure at least initially.
Old 10-03-2013, 10:52 AM
crazy96863's Avatar
crazy96863
These photos best illustrate what the cause and the damage was... Looking just at the bolts, do you know if you used the right ones?
Here is the bearing dimple after using the wrong bolt:
Wrong bolt:
Old 10-03-2013, 04:59 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
Looks like a painful mistake Crazy. Thanks for the heads up. Just o be clear that's for a roller block only correct hence the lifter hold down plate?
Old 10-03-2013, 05:22 PM
crazy96863's Avatar
crazy96863
Roller block yes... Just caught the part about being a 289 meaning its not a roller block the OP is referring to. Good info I suppose but not relevant to this issue.
To the OP... I would simply start looking at all your moving parts. Start by taking your valve covers off and checking to see if all the valves open and close without restriction. You said the short block spun normally before bolting the heads on... Its gotta be something with the top end.
Old 10-03-2013, 09:28 PM
bullmoose11
Thanks Crazy and everyone for their ideas; Last night we pulled the engine and tranny back out. We quit at 8 PM man I was bushed.
Today I went to Horrible Freight and bought telescope gauges to check the cylinders if we need to. We didnt machine the block just a ridge ream and ball hone. We ran a cleanout brush down the oil journals and cleaned them out, Then washed the block out with Dawn dish washing soap.
Tonight I pulled the plugs and backed off the rocker nuts. I tried to turn the engine over again with the long handled torque wrench.
The first 10 degrees of rotation was better but I heard and felt the sound of a dry bearing.
That kind of feeling you get when you rub a wet finger on a clean pane of glass. "Vuurrrp". Now I'm wondering if it could be a cam bearing.
The next thing I think I will try is taking the timing chain off and try turning the Cam by hand.
This what it looked like before we had to pull the engine back out. You can see my Power Steering upgrade and my disc brakes with new red calipers.
Old 10-03-2013, 09:49 PM
crazy96863's Avatar
crazy96863
You could always turn the oil pump manually to get things good n lubed.
Old 10-03-2013, 09:58 PM
bullmoose11
Good idea I did that before with a drill extension and a 1/4 in nut driver since Autozone wanted $33 for a tool. Is the oilpump suppose to turn kind of hard? I had my tool running in a battery drill CCW and it was pulling kind of hard and it didn't seem to squirt oil out the pushrods like I would have expected. The rockers just had a little bleed instead of a squirt.
Thats one more thing to look at. Ill try again and put a mechanical oil pressure guage on it
Here is my tool
Old 10-04-2013, 12:47 AM
crazy96863's Avatar
crazy96863
I turned the oil pump with a ratched... Its firm but not stiff. I would recommend using a hand tool rather than a power tool here... It doesnt need to spin all that much plus you will want to feel it.
Old 10-04-2013, 12:49 AM
crazy96863's Avatar
crazy96863
I thought it went clockwise but not sure... Try both ways but with a hand tool so you dont break anything.
Old 10-04-2013, 01:16 AM
bullmoose11
Yep its anti clockwise. clockwise blows bubbles into the oil pan. I tried it both ways, then I found a diagram which shows the rotor travels anti clockwise.
Old 10-04-2013, 06:56 PM
59JEEPSTANG's Avatar
59JEEPSTANG
59JEEPSTANG is offline
Is the transmission still on? If it is take it off and see if it is binding. If its a manual maybe the clutch is backwards. If it is an automatic maybe the tc did not engage the pump. Either of these could cause this issue. If the tranny is off disregard this.
Paul
Old 10-04-2013, 08:00 PM
bullmoose11
The AOD tranny is off, lifters and pushrods are out heads are still on, the engine is in the engine stand upside down,
We loosened up the rod bearings a little found 2 over torqued. re-torqued to 22 lbs (spec is 19-24) that helped a little.
We did the math 7 lbs per piston drag times 8 for 56 lbs The engine does turn over at 64 lbs on the torque wrench. There is a resistance point on one of the cylinders.
When the crank rotates there is noticeable scrubbing sound as the cylinders were just honed with a 3 stone and a ball hone. So we lubed the cylinder walls again with Royal Purple break in oil. That seemed to help a little.
Cylinders 1 and 5 and 2 and 6 rods had zero side play on the crank. I think there is supposed to be at least a couple thousandths, but thats a moot point, the crank and rod bearings looked good and it ran before, so we left them alone.
The new timing chain was really tight so we are going to re check the timing chain set to see if it was for a 90s fuel injected 302 and if so what is the difference if any for a 71 302 block.
Tomorrow I plan to re-torque all the rods and mains to 15 lbs take a crank torque reading as a base line then re-torque each main to spec and take a crank reading then each rod and take a crank reading.
If its still tight when all back together screw it!! Im gonna just buy a crate short block pull my cam and heads off and swap them. ... I'm 3 weeks over schedule and $350 over budget in Mechanic labor.
My mechanic guy is a chevy man.....built 35 engines over 30 years. only done a Ford or 2 so we are light in the Ford experience department.
I have a feeling the block was a remanufactured engine maybe one from the Grand auto or Kragan years where all they did was replace the worn parts like we are doing this re-ring job. When really I should have insisted on getting the block professionally re machined or just bought a crate engine, but I wanted the experience of an overhaul. So I'm paying for it and learning a lot
Sometimes going cheap is not inexpensive.
Quick Reply: Tight engine after re-ring 302
