Gem Module ?
Gem Module ?
First of all let me introduce myself... My name is Ray,I've been a Ford owner on and off for 30 years. Had a brand new 1996 T-Bird that I owned for 16 years, 4.6l V-8....What a great car ! I bought it for our family vehicle,no way I was getting a 4-door ! Anyway, just purchased a 1999 Expedition and seems I have a bad GEM Module from all the searching I have done. Can any one tell me what all this controls and where I might check to see if power is getting to it.
Here's what all is not functional on the vehicle;
No brake lights,turn signals,em flashers,no dome light,power windows don't work, can't adjust the mirrors,no radio. not sure about the 4wd button... and won't come out of park.
Things that work;
The headlights work and tail lights,back up lights,all instruments and panel lights work including the odometer.Power seats,door locks and adjustable brake and gas pedals all work as well....
Oh yeah there are no signs of water damage or corrosion in the fuse box or module...
Was getting ready to order the GEM Module and try it..
What do you think ?
Thanks !
Ray
Things that work;
What do you think ?
Thanks !
Ray
Well none of those are working so I assume I'm on the right track ?The guy I bought it from says all was working fine a few weeks ago, and He is a friend of mine so I trust he was telling me the truth. I cant believe it needs a fuse box as well. I checked the ground wires behind the kick panel and all were tight even went through the old GEM module and re-flowed soldier on all the plug contacts......Ordered a new (used) GEM tonight. Has a return policy if it doesn't work. fingers crossed.
Ray
Ray
Check to make sure the accessory delay relay in the fuse box under the dash is working properly. As far as the brakes and turn signals that could be the turn signal switch being bad on the steering column.
