Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
New Garage/Shop
Old 01-28-2015, 10:00 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
Started putting the hangers up for the third row of lights Monday. I needed to have floor space to back Darth and the van in if the weather prediction held (it didn't) so I quit in time to do that. The Taurus ground clearance isn't conducive to driving in any amount of snow. These are the three brackets I made, there are pieces to make three more. The setup puts the lower side of the reflector 8' up and perpendicular to the floor (Gary, maybe you can amend your light pattern drawing with this information). Sorry forgot to check rotation on the second picture.
  #452
Old 01-28-2015, 10:28 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Bill - I will amend it, but it may be a couple of days before I can. Off the top of my head I think you will have stronger light as I think I'd planned for them to be higher and the amount of light goes down by the square of the distance. But, the reflector will cut off the light going to the other side of the shop so you won't get as much fill and the shadows will be stronger. But I'm just going on 67 year old memory, and you know how that is - assuming you can remember when you were 67.
By the way, could you help us on Lariat_85's thread here? You know far more about plugs and carbs than the rest of us put together.
  #453
Old 01-29-2015, 10:33 AM
85lebaront2
Gary, these lights are to fill in the right hand bay, where the right side of a vehicle would be. 8' to the bottom of the reflector puts the lower tube about 8'6" up and with that side vertical my intent is to have plenty of light down to the floor and still have them low enough to illuminate under an open bonnet (Brit speak).
I did go look at Lariat85's thread and comment on it.
  #454
Old 02-01-2015, 04:17 PM
85lebaront2
Finally got a slightly warmer day to go and get 8 8' tubes down from my storage floor and install them. Saturday I went by the local Re-Store as I had noticed a bunch of electrical boxes and a decent 4 4' tube ceiling fixture I wanted to stick in the office before I start putting plywood on the inside walls.
  #455
Old 02-01-2015, 06:10 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Bill - They look good, but I'm having a bit of trouble changing the model as I don't quite understand how they are mounted. It looks like they are at an angle but don't have their backs against the curve of the structure. Right? So, do you know the angle at which they are mounted?
  #456
Old 02-01-2015, 06:44 PM
85lebaront2
The lower side of the reflector is vertical, or perpendicular to the floor. I believe you should still have the sketch I sent you of the end plates for the angle and tube location.
  #457
Old 02-01-2015, 07:34 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Is this what you had in mind? The lower reflector is exactly perpendicular to the floor and the light sits 3" off the wall. And the grid is 1' per smaller square, so the corner of the reflector is 8' off the floor.
  #458
Old 02-01-2015, 07:42 PM
85lebaront2
Looks about right. The idea was those are for completely lighting down the right side where it would be blocked by a vehicle (van or Darth, or the future Flex Limited). It really fills that side in nicely. They start back further than the others due to the door operator location.
  #459
Old 02-01-2015, 07:47 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
They, meaning the new string and the middle ones up on top, should do a very good job of lighting up that bay. Very few shadows - if any.
  #460
Old 02-01-2015, 08:36 PM
85lebaront2
Exactly, the whole floor is illuminated nicely.
  #461
Old 02-01-2015, 08:51 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
If you put a bench on the right wall you'd have really good lighting for it. No shadows from your head due to how close the right tube is to the wall. And there would be light washing down the wall to give light coming from everywhere.
  #462
Old 02-08-2015, 10:26 PM
85lebaront2
Since we have had some decent weather recently, I decided to take advantage of it and get the remainder of the left side ready for the other interior walls.
  #463
Old 02-08-2015, 10:53 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
You'll be hanging Sheetrock soon.
  #464
Old 02-09-2015, 07:50 AM
85lebaront2
No Sheetrock, probably 1/4" plywood on the service bay sides. Paneling inside the office, bathroom and wood shop TBD.
  #465
Old 02-09-2015, 06:16 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Ok. Got it, got it, ain't got it.
Quick Reply: New Garage/Shop
