Tuners, intakes, exhaust, emissions delete?
#346
Yes, you should be download the latest tunes from the H&S website and install it on your tuner.
Some people (such as yourself) who had the earlier tunes with the higher boost pressure have reported a small drop in power with the newer tunes, but from what I understand it isn't significant - and the piece of mind of not blowing a turbo is worth it in my opinion (although companies are now making 2015 turbo drop in replacement kits should that happen...).
You shouldn't need to return your vehicle to stock if you change injectors - I'm assuming you don't have the 250k warranty and are hoping to claim it however.
#347
Well I took my exhaust off, but they gave me the wrong unlock code, it is one digit too long so my truck didn't run right. The pyro 2 sensor reads 1100 something when it's cold now, hoping when I get the right code and install the custom tune that it will work right? Not sure. Do I gotta get an aftermarket pyro sensor now or what? No where to put it on this new pipe I got.
#348
#350
The reason you have to put your truck back to stock is because the Ford computer inputs the new IQA code for the injector you are "flashing" the truck which will render your tuner worthless. Me and the local SMT almost had that scare. He called me about 2:00 in the afternoon asking me where the tuner was. I had to leave work and run it to him so he could deprogram the truck, input the new IQA code and then re-tune the truck. It will basically brick your tuner because it thinks that the "tune you can only use on one truck" is already used up, so it won't let you tune another truck.
#352
I did the updates and the truck seems to be idling smoother and running better.
Had a bit of a scare when I got the "stop safely now" and engine shut off after 3 seconds. Had to make a call to learn I'd loaded the wrong files (6.7ENG), once I loaded the SPEENG and TRAN it ran great and has been for another 5000 miles.
My boost numbers have not changed. Still climbs to around 30psi if I don't back off on the throttle.
While on the phone with H&S I asked about injector replacement. He basically said what Tofan is saying. Return programming to stock before starting work, then after the work and flash is complete, return to tuner program before starting and driving home.
#353
just completed my emissions/exhaust/egr delete and was out testing it and all of a sudden my truck died and i got a low fuel pressure warning. Never seen that before and ive had the tuner on with the stock emissions for about a year, took the exhaust off a week ago and just tonight removed the egr system. After it died I coasted for a mile or so, put it in neutral and tried to restart once while still going around 30mph and it cranked an cranked an cranked, no go. Coasted to a stop and waited another minute or so and tried again and it fired right up and i continued on as normal. anyone ever experienced that? wtf caused it? why did it never happen before the egr delete? did I mess something up?
#355
#356
I have spe hot tune and my boost goes to 30 psi on performance, but it's lower on the lesser street and towing setting. The trans also shifts much harder after installing it, sometimes bangs into gear pretty hard. Was using h&s tune before and boost was 24, trans shifted way smoother. Gonna call spe later and see what they say, will update. Was just curious if anyone else experienced that. Thought I blew it up at first cause I was on performance and getting after it
#357
#358
I think he was using h&s but I just mentioned it to see what you'd say, what does it matter if spe or h&s? If 30 is bad isn't thirty bad no matter what tune? I don't understand. I appreciate your knowledge, thanks for sharing.
#359
That being said, SPE tunes will use more boost and no doubt create more power. However, I still think the excess boost above 25psi is a problem for the stock turbo. That's just my opinion and I think the staff at SPE knows what they are doing. I'm just a chicken and don't want that much boost is what it boils down to.
Darren straightened me out a while ago. I was running an older set of tunes and defueling to control boost. Why? He suggested that I just run what you know is conservative and safe and be happy with it rather than constantly defuel. He was dead on and I can't be happier with the truck now.
This is not to say the guys running SPE tunes are going to blow turbos or anything close to that. I'm just saying I prefer tuning of H&S which is making good power at lower boosts. The SPE tuned trucks will blow mine away for the record
#360
on
I don't know if this is bad for the pump or not. It just can't keep up and the pressure in the rail drops and at some point the ECM shuts it down.
You either need to modify the tune to use less fuel or better yet ... get a bigger pump or 2
