Issues with Red Head boxes or not? A discussion
Old 04-14-2014, 05:53 AM
sammie0126's Avatar
sammie0126
sammie0126 is offline
Originally Posted by Lance Helmert
So with no new posts I'm assuming the new box is working good? Hope it is. Would you buy another one? Thanks for all your helpful threads.
Yes it's working fine, no other issues with it or pump failures.
  #92
Old 04-15-2014, 03:53 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
Thanks for the input I followed this thread and can see one that had problems. What type of problems have other RedHead owners had? Is the general consensus that these are good just have a few bad one every now and then? Or is it better to get a Ford Reman?
  #93
Old 04-16-2014, 05:54 AM
sammie0126's Avatar
sammie0126
You will get many opinions on that question mine is...
1. A reman is a reman and always carries a risk that the reman was not done properly.
2. The steering boxes for these trucks (OEM from the factory) in my opinion were not sufficient to handle the needs of an EX. Some have made it 100k plus without issue but a large majority have not.
3. Based on #1 and #2 I would not install a Ford Reman, therefore I went with Redhead. I did have a loose valve in mine and had to have it warranty replaced. You run that risk with any part, which is why the most important step in deciding is "what's the warranty".
  #94
Old 04-16-2014, 11:33 AM
EXv10's Avatar
EXv10
EXv10 is offline
Reman or rebuilt, less money, same thing. Redhead claims to bore for needle bearings but it's only to salvage worn out cases that were originally shaft to case (no original bushings) so that could be one out of 500. This is a discussion right?
  #95
Old 04-16-2014, 12:25 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Yes it is a discussion now can you post proof that they only bore out 1 in 500 steering boxes or is this Brent logic at work ?
  #96
Old 04-16-2014, 12:39 PM
Bigpipes 35
This is off their website and while the Ford boxes came from the factory with needle bearings a lot of the older boxes didn't, They do size every box with over size ball bearings to take out all play in the box.
Red-Head Steering Gears Re-manufacturing Process
• Machining out the housings and installing needle bearings
•Flame-spraying or replacing the shafts as needed Installing new control valves on some applications
•Custom fitting each worm & piston assembly with special ordered, precise over-sized ball bearings.
  #97
Old 04-16-2014, 12:46 PM
Bigpipes 35
Here is what they do on a A1 Cardone, no wonder they call them a spray and pray..
100% computerized hydraulic testing measures for proper flow, leakage and performance to ensure perfect fit and function.
• 100% new o-rings and lip seals ensure no leaking and long-lasting performance.
• All critical components (campacs, spool valves, etc.) are triple-tested to ensure product reliability.
• Rust inhibitive "Cool Dip" finish is a penetrating dye that completely covers all exposed surfaces for a consistent, protective finish that will not crack, flake or peel.
• Shafts are surfaced to precise specifications to eliminate premature seal wear and extend gear life.
• Units are supplied with 100% tested and calibrated pressure relief valves for guaranteed performance
  #98
mecdac's Avatar
mecdac
mecdac is offline
Been looking at these Redhead steering boxes for a while...subscribing.
http://instantrimshot.com/classic/?sound=crickets
  #99
Old 04-16-2014, 12:52 PM
Bigpipes 35
Here is the rebuilt process from another cheap auto parts rebuilder..
•Internal components are inspected for wear and replaced if necessary
•Gear boxes are factory pre-set to OE specifications
•New OE quality O-rings & seal packs provide leak proof installation
•Input and output shafts are inspected and replaced when necessary to ensure quality and performance
•Mounting threads are cleaned and hand chased for easy installation
Wow,Good thing they clean them threads..
  #100
Old 04-16-2014, 01:02 PM
RigTrash601's Avatar
RigTrash601
RigTrash601 is offline
So basically they clean them up, jury rig any minor leaks, and send them on their way. ( I love all "when necessary's" there are).
  #101
Old 04-16-2014, 01:21 PM
EXv10's Avatar
EXv10
EXv10 is offline
Read between the lines. I'll be back tonite............busy
(if they don't start deleting everything)
  #102
Old 04-16-2014, 04:40 PM
EXv10's Avatar
EXv10
EXv10 is offline
It's just the cases that don't originally have any bushings, worn out, and that they think are worth saving so that isn't going to amount to many at all. It just saves them a little money.
  #103
Old 04-16-2014, 04:50 PM
EXv10's Avatar
EXv10
EXv10 is offline
>Nope, it said needle bearings when needed on worn out non bushing cases.
>Yes everybody fixes or replaces things that are needed.
>You have to either grind the steering worm and install bigger ***** or replace it. (special ordered precise bigger *****) ......no way around it unless you want to make a steering worm which ain't gonna happen.
  #104
Old 04-16-2014, 04:53 PM
EXv10's Avatar
EXv10
EXv10 is offline
Looks like they use hype too but you really have to read between the lines unless you have worked at all these places. Triple tested?.......come on.
  #105
Old 04-16-2014, 04:57 PM
EXv10's Avatar
EXv10
EXv10 is offline
This is more down to earth but again; they all do pretty much the same thing and nobody is making any new parts or doing anything that will cost them more money unless their quality is taking a hit. It really boils down to who has the best reputation and the longest and best warranty. Isn't Red Heads' just one year?
I'm glad they cleaned the threads........lol, but they "say" they chase them to which others may or may not do. (we will never know).
Quick Reply: Issues with Red Head boxes or not? A discussion
