Issues with Red Head boxes or not? A discussion
Old 09-17-2013, 03:06 AM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by PROSTOCK
I've got 45K on my RH box and no problems, fixed the issue and have been real happy. Sorry to see others not as lucky(?).
I need another for my '65 and was set on RH, maybe no?
Just another rebuilder, I would get one from the parts store for convenience.
  #77
Old 09-17-2013, 04:58 AM
sammie0126's Avatar
sammie0126
sammie0126 is offline
I am happy with my new one (warranty) my steering it tight now. That being said I did have one failure so I can't say if it was just a fluke or a problem until I put some miles and abuse on this one and see if it holds up. I about ran over the curb on my first test drive after install because sheesh the truck turned when I moved the steering wheel.
  #78
Old 09-17-2013, 07:14 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Great to hear! With as much slop as we seen in your last box I bet it is like a whole new truck!
Sloppy boxes are no fun! LOL
  #79
Old 09-17-2013, 10:53 AM
EXv10's Avatar
EXv10
EXv10 is offline
  #80
Old 09-17-2013, 07:25 PM
PROSTOCK's Avatar
PROSTOCK
PROSTOCK is offline
OH yea? That's where I got the one I have now and the output shaft bushing / bearing is completely gone. Don't want to repeat that. This truck only sees about 500 miles a year, it's not like this box has a lot on it now. Lifetime warranty is great if you don't mind replacing it for a lifetime. I like one and done...
  #81
Old 09-17-2013, 08:43 PM
EXv10's Avatar
EXv10
EXv10 is offline
Oh yea? Christinas' Red Head went out in just a few months. I would spring for the lifetime warrantee myself. All you can do on those things is grind the worn parts down, add new bushings, replace the steel ***** and any other parts it needs. Redhead is just another rebuilder, oh! but they do paint the top red.
  #82
Old 09-18-2013, 07:00 AM
Snowseeker's Avatar
Snowseeker
I'd like to rebuild my own, bore out the housing, install the bearing, new ***** and stuff, great fun!
  #83
Old 09-18-2013, 11:19 AM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
A new career in you future perhaps...
  #84
Old 09-25-2013, 02:30 PM
sammie0126's Avatar
sammie0126
I got my core back today on my warranty replacement and also got the email Harvey had promised. Now take it for what's it worth but at least he did send me a note on what they found.
<!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]--> In your case, there was a pin in the valve that came loose. That's what was causing the play.
Thanks,
Harvey
  #85
Old 09-25-2013, 07:03 PM
Snowseeker's Avatar
Snowseeker
If I could get 3-4 done per day maybe.
  #86
Old 10-01-2013, 03:57 PM
Bigpipes 35
As a matter of fact:
https://www.ford-trucks.com/forums/1...rebuild-2.html
I personally wouldn't want anything in my cooler lines that could block up and stop flow.
Thanks a lot Andy, you jinxed me my magnafine is leaking in that exact same spot now,
  #87
Old 04-12-2014, 11:20 PM
Lance Helmert's Avatar
Lance Helmert
Lance Helmert is offline
So with no new posts I'm assuming the new box is working good? Hope it is. Would you buy another one? Thanks for all your helpful threads.
  #88
Old 04-13-2014, 08:56 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Since my second power steering pump, I've had no more woes. It wasn't a red head issue, just bad luck with the first ps pump.
  #89
Old 04-13-2014, 08:58 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
Where is a good place to get a PS pump? Ford, cheap parts outlets or another place?
  #90
Old 04-13-2014, 09:44 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
I went to RockAuto, a sponsor here, but don't get the cheapest one there. Also ordered 2 new hoses, but not the hose to the reservoir.
Quick Reply: Issues with Red Head boxes or not? A discussion
