Sanderson FE Headers PN FF427 Reference Pictures
#34
Sanderson headers are very nice from what I've researched. They use a thick header flange so that you don't need to use a gasket. Im still alittle weary of that part. But will probably be using them on my 460 build.
Can't believe I haven't seen this thread until all these months later. Those headers look great. Did you end up getting a mini starter yet? I've had to replace my starter before from being cooked by the headers. now all I will run is mini starters when I run headers come hand in hand. No more worries of letting me sit now. Is anyone running a 460 with Sanderson headers? I found a pair for sale but the guys having part number issues so I don't know what ones he has. Anyone know enough about sandersons to tell them apart?
#35
on
2x on the mini starters.
If you have a auto trans and your not parked at home in your driver way and the starter craps out your dead in the water. Time to call a tow truck..
Where as if you have a stick shift trans you can ask a few guys for hand to get it push started to get it home so you can remove the header and replace with a mini starter.
Hopefully that will be the last starter you'll have to change out for a long time.
But next time a mini starter will be of ease if needed changing out..
orich
orich
#36
^ totally agree and that's the exact scenario that happen to me. was at the gas pump filled up got in and the starter was heat soaked and fried. Lucky I was in my 73 challenger with a 5 speed so I pop started it. Got it home ordered a mini starter never looked back. Added benefit smaller and lighter to maneuver when bolting up.
#37
The moderators felt it was fine to make it a sticky there but not in here for whatever reason. Perhaps 67-72 users could clamor to have it replicated in this forum
https://www.ford-trucks.com/forums/1...mpilation.html
#38
#39
Go for the front-mount swaybar found on Dentsides... the most laborious part will be obtaining and installing the bracket which goes over the I-beam to radius arm thru-bolts.
#40
The header collectors will exit down by the pan rail. If you're talking about the CS swaybar which bolts across the radius arms it'll need to be ditched.
Thanks for the help!
#41
Well good news is I have a dentside! Bad news is its a super camper special so fitting headers is next impossible. The anti roll bar and the extra large cross member are in the way. I would like to see if these fit. I will also snoop around and see if anyone with an scs has tried these.
Yeah, I read and understood your post the first time....... that's why the swaybar which mounts btwn the radius arms needs to be removed.
#43
.. and contact them with fitment questions. It looks like they offer a coupla 302 shorties.
#45
