Super Duty vs. F-150 - what am I missing?
#31
Haha...some good responses... never too much power...only 4 inches vs. 10 with the 150...
I couldn't do a Raptor. That's an attention get-ter, and as it is I'm going to have to explain to people why I'm even buying a truck. The Raptor is way out of my comfort zone. I like heavy duty tools, things that don't feel like they'll break very easily, and the 250 has that in spades.
#32
Sorry, we got rid of the carseats over 30 years ago! However, I'll tell you that there is really no comparison between the Ford F-150 and a Superduty Truck. The only thing that is close, is the fact they both look like trucks a city block away.
Now compare the axles, suspension, powerpackages, load capacity, towing capacity and inside room, there is simply NO comparison. The Superduty is a heavy duty.......that says it all simply put gentlemen. My next truck will be an F-450 Superduty in about 3 or 4 more years the wife willing of course.
#33
Out on the ranches, you'll see a lot of f150's owned/driven by the foremans and hands.
The only time you see the 250/350 is by the ranch managers and owners. Mostly because when big equipment is moved, it's usually a higher pay grade out there runnin the show.
With that said, the f150 is a very capable tool in the sense that it will tow whatever you have, haul what you needs and carry enough butts to warrant not needing the diesel.
I can't imagine you're going to be pulling a 30' big tex 5th wheel with a 800 series challenger on the back.
F150 will serve you well.
#34
#35
My truck criteria sounds similar to yours. Go get the Super Duty and be done thinking about it. Like you said it looks better to you AND to a lot of others these days. IMO the resale potential is better than the 150. I would have gotten a diesel if I could afford the additional costs. I still feel like a kid driving my truck after 2 years of those darn payments.
#36
I've got 4 kids. 3 are in Carseats or boosters. In the F150 the car seats physically touched each other. No room for anything else and the outer 2 touched the door panels until I bought my son a different forward facing skinnier model.
Same car seats in the F250 had hand sized gaps between each and a hand gap between for panels.
Strangely those same car seats in my 2008 Expy EL never touched in the 2nd row. Always confused me because the Expy and F150 share same cabin specs. ...ish
Yes the F150 clearly has more room then the SD. My son would always kick the back of my seat when he was back there(in the F350) I noticed in the F150, he could not reach with his feet. I took the truck(f150) up north this past weekend and both rear passengers mentioned there being more leg room back there for them.
To the OP:
Your needs don't require a Super Duty. Who cares. It's your money, buy what makes you happy. Half of the Super Duties I've owned were overkill for my needs, I loved driving them anyways.
To the OP:
With my seat in normal position and the booster behind me I can climb in there without a problem. Having JUST traded in a 150 for a 250, there is NO way you could convince me the 150 is more roomy.
#37
#38
on
Thank you, Fastfwd. I'm going to drive another 250 just to see, but I doubt the ride will bother me. Do you have a diesel?
It sounds like overall that you're happy with your purchase. That's good.
One other comment on the 150...it's a bit 'slab-sided' in appearance. The 250 has a nicer look, with better lines.
For that reason, my next truck will be an F350...no difference in the fees/costs from the 250 and not much of a premium from Ford either.
#39
One thing not mentioned yet probably depends on the state you live in but here in IL, due to a gross vehicle weight rating in excess of 8000 lbs, my F250 requires twice yearly IDOT safety inspections or an IDOT registration which cuts the safeties to once a year. Also requires D plates due to weight. Insurance is also higher on the 250. Chicago city stickers more $$. Overall, here in IL, the additional fees and registrations add a couple of grand a year.
As for rear seat legroom, it looks like the 250 has an inch less of room. I will say that having sat in the back of both the 150 and 250, that the 150 does appear to have more legroom. At least that was my impression...
#40
on
Good points, LMS. I was wondering what the laws might be in VA. A couple of grand more is not insignificant. It's like buying an $8 hot dog at the Verizon Center. You may have the money, but it makes you want to avoid the purchase.
#41
I should have noted that the lions share (about 1300 bucks) is exclusively relative to the insurance premium on the F250. On a business plan here, they treat it hardly different than a heavy duty truck. My guess is that it's physics at work....the SuperDuty trucks tend to destroy what they hit unfortunately.
#42
#43
Looks like Tylus, myself and the specs straight off Ford disagree with you. Maybe the 150 has adjustable pedals and that has bought you some room?
Did you even look at the specs? Maybe you should..
I don't need to convince you of anything, I have nothing to sell here.
Here are the specs that disagree with me:
2013 Ford F-150 | View Interior Specifications | Ford.com
2013 Ford Super Duty | View Interior Specifications | Ford.com
#44
Very good points here. Safety stickers and D plates are a joke here in IL. I traded my '05 F350 in for a '13 F150 and was shocked to get a check from Allstate for the difference in my premium.
#45
A thread I can *really* relate to. Last week I traded in my 2012 F-150, Ecoboost, crew cab with 6.5 foot bed for a 2013 F-250 6.7, crew cab with 6.5 foot bed. My F-150 also had tow mirrors, so these two trucks are almost the exact same length and width. I stepped up to the 250 because I needed the towing capacity, and the 150 wasn't quite enough. Plus, who can argue with 800 ft lbs?
Others above have already mentioned the differences between these trucks, but few have actually owned the recent models like I have and had to live with them. Here's what I've noticed in my one week of ownership. These are relative comparisons, so don't take any of them to mean either truck is 'bad.'
- Fuel economy. I was getting around 17.x MPG in the F150; I'm seeing around 16.x in the F250 on the same commute.
- Ride quality. The 250 rides quite a bit rougher, although I'm hoping that upgrading the shocks (I have the FX4) and steering stabilizer will help. It isn't bad by any means. It's just that Ford has really tuned the F150 to ride like a car almost whereas the 250 rides like a truck. Road / wind noise is about the same.
- Handling. The F150 definitely handles better. It tracks straighter and takes the turns better. It feels more agile.
- Power. This is the strange part. The 6.7 in the 250 has more power on paper, but the 150 with Ecoboost accelerates quicker, as confirmed by the 0 to 60 times in car reviews. Throw an 8000 lb trailer on the back and I'm sure this equation flips.
- Height. Parking garages can be an issue with the 250, which is around 5 inches taller than my 150. My 250 can't fit in the airport parking garage, whereas the 150 could.
- Weight. According to my local CAT scale, my F150 weighed 6000 lbs, my F250 is 8000 lbs. That makes the fuel economy of the 250 pretty amazing, considering that it's carrying around 33% more weight.
The 150 is a better vehicle for day to day, non-towing driving, but I still like the 250 better so I have no regrets, especially if you need the towing capacity like I did. Let me know if you have any questions about these two fine trucks.
