Slip yoke on a long bed '66 F100
First off, I want to say I recently purchased a '66 f100 long bed with a 240 I6 and a 3 speed. I've trolled this forum quite a bit when deciding on my purchase and it's nice to see such a helpful group of owners and I hope to be able to contribute soon.
Now to my question/issue;
I noticed that the splines on the slip yoke coming off the intermediate drive shaft are exposed by about 2 3/4 inches after the bearing. Is this normal or what do I need to do to repair this? Thanks ahead of time for any help with this.
I hope the picture helps explain things.
And yeah, get yourself a new carrier bearing/rubber part. That one is hosed. Can and will cause extra driveshaft vibration.
D9TZ-4800-A .. Driveshaft Center Support Kit / Available from Ford.
Kit includes all the shims, center support bearing, brackets and rubber support.
MSRP: $96.83 // FTE sponsor PARTSGUYED.COM price: $69.72.
Thank you NumberDummy. Where were you able to find the part number for this? Is there a parts guide with diagrams available somewhere online?
In 1979, Ford came out with this kit (D9TZ-4800-A) that included all the parts that once were only available separately.
Thanks again! I'll check it out. I already purchased the Ford factory service manual for my truck so I guess the parts catalog will be the next purchase.
I have a question about the slip yoke in that picture. I noticed he is missing the part that threads onto the slip yoke where the threads are exposed. I have a broken piece of rubber gasket which has groves on it to fit in the slip yoke. Also there is a washer with grooves in it that goes on there. What is the purpose of the rubber washer and the threaded part? Where can I buy a replacement rubber washer with grooves in it?
on
The grease seal is missing because it was never there originally.
How could you grease the splines, since there is no Zerk (grease) fitting on the slip yoke? By hand, would be the only way.
The only Zerk fitting (as original) in this location will be found on the center U-joint-used to grease the U-joints cups.
The replacement U-joints used after the 1970's do not have a provision for Zerk fitting.
Has the slip yoke been cut? The OP will have to measure it to find out.
C5TZ-4841-F .. Slip Yoke-Overall length: 7 1/8." / 1965 F100 240 I-6 w/a 129" wheelbase.
This yoke has many other applications, I only listed the one that applies.
My '65 F250 has a zerk ftg. on the slip yoke, as well as a knurled nut that threads onto the yoke. I suppose that these items may not be factory-a zerk ftg. can be added without too much trouble. By the way, the shaft bearing will have to taken to a machine shop to press off and on. I learned that one the hard way. Good luck.
Kurt
Kurt
