Snorkel Tube Replacement W/Pics
<hr size="1" style="color: rgb(255, 255, 255); background-color: rgb(255, 255, 255);"><!-- / icon and title --> <!-- message -->
<!-- google_ad_section_start -->Great info on this site, thx.
I found a version of the Gotts Mod on here, using the F-250 snorkel tube to to open up the breathing a bit on the F-150.
Very simple 10 mins. Direct fit. Only cost $5.
Throttle response is improved a little and seat of the pants feels a bit stronger on launch. Here are some pics.
Old Tube:
New Tube & part #:
Side by side of old & new tubes:
New tube installed:
Old Tube:
New Tube & part #:
New tube installed:
The tube is for a 2005-2010 F-250 6.8 liter V-10.
The benefit of the tube is to pull in cooler/cleaner air from the behind the fender well which is separated from the engine compartment by a piece of heavy duty rubber sheet (once you take the air filter box off you will see it) vs the hotter engine compartment air. Also the tube helps to protect against road grime, leafs, and moister from heavy rain and snow ect....
Nothing had to be modified it is a direct & perfect fit. The 2011 and up 5.0's and EcoBoosts come stock with the larger tube from factory.
Hey D8chumley....I had custom 5 Star tunes for my V-10. They were awesome. How much did they improve your 5.4. I also have a 2010 5.4 & need to do something to wake this hog up!. Were the tunes worth the $$$$
Yes they were, especially for the shifting. Mike is on the money with his tunes. I would recommend him to anyone, and his customer service is awesome as well
its the got's mod all over again.
with all the holes in the side of its tube/ snorkel there's tons of hot motor compartment air getting in there, so I don't see any real advantage. and hod do you get it in the inner fender? cut hole biger or a flush nount? Plus in the newer trucks don't you loose the lower end power and only gain about .5 to 1 HP plus it eats up MPG I heard.
just playing devils advocate I am not trying to **** in any ones Wheaties!
I got it new at the Ford Stealership. Give them the part # I posted. Its just over $5 bucks. Your parts guy is looking at the wrong part.
Tasca has it.
2010 FORD F-250 SUPER DUTY Parts - TascaParts.com
just copy and paste the part number
7c3z9f721a
7c3z9f721a
ddbck - Is there a good dry drop in filter to use with this, better flow than than stock?
Any increase in air flow comes at the expense of filtration.
-click- the pic'
Goth 150
< This space intentionally -blank- >
