complete dodge power train in to a f250 4x4 2003
hi any one did a 2003 f250 conversion with a complete dodge cummings powertrain? including transmission transfercase, out from an 03 dodge ram 2500
where to position the engine? measuring points?
my tuck was a v10 4x4 4 door short box.
engine removed, with trans, cab is off the frame.
i have a complete dodge powertrain out from an 03 dodge 2500
i have the complete engine transmission transfercase fron, rear end fuel system, radiators, wiring harness.
im not going to use the ford transmission
using the dodge power train isthe most effective way to converting it in my case
. i prefer to keep the ford rear, front end, but if needed i can install the dodge suspension, front rear end .
i need some starting point
so what i need to cut remove from the ford frame?
how to make a motor mounts what to use? ideas?
im going to use the original dodge mounts
im not going to buy any pre made mounts so i will have make them
any info will help thank you so much for all of you
