What are you guys doing for U-bolt plates after swapping in a 60 front?
I have the original lower plates, but rockauto only sells one size square U bolt, and I know I need different sized ones. Thinking about just converting it to a top plate that sits on top of the spring. Any one have the measurements for what I need? Normally I'd just start measuring and building, but I'm not by the truck.
I used the u bolt flip kit from WFO Concepts. Worked just fine. Had to clearance the drivers plate a little to clear the stock steering arm. I will be going to crossover soon. Crossover will clear with no issues.
https://www.ford-trucks.com/forums/s...181279&page=10
i cut the web, jumped the **** out of my bronco for years and never had a problem with alignment or getting axles back in for what its worth. I used the ruff stuff plates i believe, i think i had to enlarge the holes for the inner bolt on the driver side plate to accommodate the ~4" diameter housing width. they worked great.
I just used 1/2" thick steel plate & drilled holes. There were 2 different size U bolts needed & I ordered those from Ruff stuff. If I remember right the 1 larger u-bolt that goes closest to the pumpkin on the driver side was 3.5" and the remaining 3 were 3.25". Been a few years since I did this though so my numbers may be off.
Here's a couple pics of mine - they're not hard to make. It I was all fancy like I'd stick them on a mill & do pockets/ribs like lightweight aerospace stuff for bling points, but I was lazy.
