88 460 poor running when warm
Working on a guys 1988 E350 motorhome. Says that after 40km or so on a warm day it loses all power and barely runs, he has to pull over for 15-20 mins then start off and do the same routine over again.
New TFI module (My Bronco II was having the same symptoms when its TFI went bad, no change with the 460 )
Fuel pressure 30 at idle, 35-40 when the throttle is tapped 20 when held at mid throttle in park. 40 at idle with fuel regulator vac unplugged, 40 when throttle tapped. 25 when held at mid throttle.
KOEO code 33
KOER code 21, 33
Any suggestions? I cant replicate the problem. When I drive it it works fine, never get a chance to drive it on a warm day. Might have to take it out and go fishing!
KOEO code 33
KOER code 21, 33
55widebed
04-14-2017 09:36 AM
tbirdscott
08-22-2013 12:54 PM
4rd1ton
12-07-2012 09:00 PM
drpdlr
06-13-2003 08:35 PM
mtflat
12-10-2002 08:51 PM
