19.5" Tubeless Wheels 8 lug 6.5" bolt pattern
Category: Wheels & Tires
Price: $110
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic, '92+ Civic/EL & Del Sol, '06+ Civic/CSX, Prelude
Item Condition: UT
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
for your 1948 1952 F-2 F-3 etc
These have the hubcap clips. I did not see any part numbers on them but can look closer if need be.
The first wheel pictured was on a 61 or so F-250 rear axle so it did fit over the axle hub fine as is. I have not measured the center hub opening diameter of the other two yet, but I suspect that that hole will be slightly smaller diameter so may not clear the rear hubs on an f-2 f-3 but would fit the front axle fine.
I'll double check on this measurement.
first wheel comes with an old tire (or can be removed if required)
second and third wont don't include any old tires. unless you need or want some.
I've shipped with Fastenal in the past with great results, and reasonable prices.
or local pickup welcome as well.
located in Salt Lake Utah
PM, me or email at jf m a d s e n at y a h o o dot c o m
or calls ok too 801-694-Eight 8 26
thanks for looking
stockcar1974
12-20-2011 08:58 AM
jimkaray
11-13-2003 12:27 PM
