diesel f-350 questions
I am thinking about buying a 94 f-350 4 door with the 7.3. my questions are how good are the non-turbo 7.3s and how tough are the auto trannys? i have never owned a diesel ( have driven many with the turbo) i was told that this one would have no power and i would hate it. also it has the auto in it and the truck has 270000 miles. it runs very good, with no pings at all...it is very quite for a diesel. i can get it for 2000 cash, the body is rough..but i dont care about that..i work in a body shop so i can fix all of that! no rust at all and great tires....it has just been used as a truck....any help would be great, thanks
The 7.3 is one tough Diesel... Most prefer the Turbo'd version. I was looking for one, but not being a diesel expert and owning and old truck are a bad combo... That, and if it does up and die, diesels are that much more expensive to replace, so I went the gas route... I can fix near anything on my 460, and that's the way I like it
That thing will have a ton of life left, IF it has been properly maintained over the years (if it was a work truck, then it may or may not have been) Guys have put 500k + on those things with no sign of slowing down
The auto tranny's seem to be the weak spot in these trucks. At 270k if it has never been rebuilt/replaced, you can bet it will probably need it if it has been worked hard.
Mine has 270k (Kms) and I believe it to be the original non rebuilt tranny, but I don't know that for sure. She shifts fine, and the fluid is clean and doesn't smell burnt... So its likely been rebuilt at some point
Received 3,186 Likes
on
my 88 currently has a little over 496,000 miles on it.
a turbo can be added very easily for under $1,000.
they show up on ebay, craigs list, and even here all the time.
the difference between a turbo and a non turbo truck is night and day.
but one thing to remember, these are not race trucks. even with a turbo, it will be one of the slowest things on the road, but it will pull a house down without any problems if asked to.
My '92 with the non-turbo IDI is about to hit 296k, and it's still going strong. The previous owner had the transmission rebuilt at around 170-190k, and it shifts fantastic.
It is slow as can be though. I've thought about a turbo, but I figure since it doesn't have the reinforced internals like the IDIT, it's better to save my money and be patient. It'll get up to speed... eventually.
on
retiredgeologist
02-26-2010 05:20 AM
kris_s_toy
12-03-2005 06:49 AM
GunNut
05-28-2004 09:55 PM
