Back Up Camera
Your best option will be replacement of the camera. I have baked a camera similarly affected (not a Ford camera) in an oven at low 160F or so for a number of hours and successfully driven the moisture out, but you need to be able to fix the failed seal in order to make a lasting repair. A purge with a dry gas (nitrogen, argon, etc.) if you have it available can also help.
TammyGann
04-21-2017 11:34 AM
mawscode
09-26-2004 10:00 AM
