48 F1
Old 02-02-2015, 09:23 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Found this pic on my computer......
Nice work on the chassis so far!
  #62
Old 02-02-2015, 09:33 PM
trumph's Avatar
trumph
trumph is offline
Ha good one Tinman got some of a yellow coupe somewhere too
  #63
Old 02-13-2015, 07:03 AM
trumph's Avatar
trumph
trumph is offline
Back home from work and into the shed spent most of the day measure measure measure but confident I now have the jag front end in the right spot and started making the mounting brackets
Played around with some patina ideas to match in after the rust repairs
And finished off with a couple of cold ones watching the sun go down
  #64
Old 02-14-2015, 07:48 AM
Harrier's Avatar
Harrier
Harrier is online now
That sounds like a great day and a beautiful sunset.
  #65
Old 02-16-2015, 07:31 PM
trumph's Avatar
trumph
trumph is offline
Back into it again, have all the marks and measurements to soft mount the ifs so dropped the front and rear ends on the ground and started the chassis clean up set up the rotisserie on it and turned it over, just love things that make jobs easier
started making up the mounting brackets for the front end
  #66
Old 02-27-2015, 06:18 PM
trumph's Avatar
trumph
trumph is offline
Well the mounts are finished and now welded in place
Made up the main crossmember for the K frame and have cut all the boxing plates ready to go, turn the chassis back over tomorrow and mount up the front end
  #67
Old 02-28-2015, 11:05 PM
trumph's Avatar
trumph
trumph is offline
Well turned the chassis over and with a wiggle and a couple of taps the front end mounted up real nice
Got stuck in this morning and made up the shock mounts
Small modification to this one for the chassis number
Filled in the front cross member just to neaten it up
  #68
Old 02-28-2015, 11:34 PM
burnettd01's Avatar
burnettd01
burnettd01 is offline
Jag IFS
Looking good Trev.
You're moving along quickly.
Keep posting the photos - we're interested in your progress.
Take Care
Dan
  #69
Old 03-01-2015, 09:00 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Looking good and back on 4 wheels! Great progress.
Keep it coming....
  #70
Old 03-02-2015, 04:36 AM
trumph's Avatar
trumph
trumph is offline
Thanks Dan and Scott, trying to get as much done as I can while I'm home working away has its good points but also its bad, means I got to squeeze as much as I can in before I'm off again, anyway welded in the back cross member and started boxing in the frame
Surprising how long it takes just doing that bit at a time so it doesn't get to hot, and once again finished off the day cleaning up
  #71
Old 03-02-2015, 11:28 PM
trumph's Avatar
trumph
trumph is offline
well that was a slow job to do but at least now the frame boxing is nearly finished
And there she sits while Im away for another week
  #72
Old 03-11-2015, 10:59 PM
trumph's Avatar
trumph
trumph is offline
Home again, made up some new rear shock mounts now I have the new shocks and springs together
Hopefully pick up the motor and auto this weekend and have it sitting in place before back off to work
  #73
Old 03-15-2015, 04:34 AM
trumph's Avatar
trumph
trumph is offline
Managed to pick the motor and trans up and mocked up into position with radiator but will sit the cab on tomorrow just to make sure clearances are ok
  #74
Old 03-15-2015, 09:46 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
For sure put the cab on to check.....to me it looks like your engine is way too far back, unless you plan on a firewall recess. You can move the radiator support to the forward set of holes and gain a couple inches.
  #75
Old 03-15-2015, 08:42 PM
trumph's Avatar
trumph
trumph is offline
Hey Thanks Scott good eyes you got there, mounted the cab and moved the radiator to the forward mounting holes and is still a little tight,
I can still bring the motor back another inch which is what i will do , apart from that it looks fairly good sitting in there, got about just under 2 inches from the sump to cross member, was worried i might have to look at rear sump hump.
Set the carb mounting face to 0 degrees which i have heard gives a 3 to 5 degree angle at the transmission shaft ?
Quick Reply: 48 F1
