New to F100s. I know this is already here but I looked through a dozen pages and didn't see it. Anyone putting bed liner, like Rhino or Line-X on their running boards?
I did the spray on liner. A shop did both boards for $100 They came out real well and are not slippery.The truck is now 5 years on the rebuild and they still look good, after 25000 miles.
that's what I'm going to do. and I've heard you can paint over it but no idea if it matters what kind of paint. My truck project has a low budget, my grill is black, and I'm going with black steel wheels so I'm going to leave the running boards black too.
I am using bedliner on my boards, Upol Rapture. I am old enough that i need the boards to get in and out and there is no need to scratch up some pretty paint.
If you look closely at the pic of the blue truck you will see that the FG rear fenders have been coated on the inside with Rhino lining. Some of the products available today can be tinted but this truck has had the bed liner painted with the same paint as the sheetmetal. There is an adhesion promoter that is recommended if you intend to paint over the bed liner...this truck has been on the road for about 4 years now and the paint still looks great.
I used it for the bed and running boards and did it in a color matching. My bed was a little rough and I wanted to keep all the original sheet metal so it also helped out in hiding small imperfections. I build my truck to be a driver and I did not want to worry about telling my friends "dont step on the running boards.
I'm also thinking of having the insides of the fenders coated with bed liner, just where they are in the line of fire from rocks coming off the tires.
Anybody else tried that?
I did. I'm sure it helps some, but I still have some "rock stars" showing up in my fenders. I think putting it on really thick, or using rubberized undercoating over it would help. Not living on a gravel road would help too......
