5.4 Lean code's.
Old 07-23-2013, 05:00 PM
77mud's Avatar
77mud
77mud is offline
5.4 Lean code's.
My mother has a 2000 Ford expedition the Radiator blew 3-4 months ago and the CEL came on. I put my scanner on it checked it and it showed a P0171 and a P0174 (bank 1&2 lean) so i cleared it and told her to let me know if it came back well the other day she came to me and said it was on (and had been since the day after I had cleared it) well i swung by a buddys shop and he put his big High dollar computer on it and said that looked like Bank 2 down stream O2 was bad, So i changed that Yesterday drove it a few miles nothing came on so i dropped her car off to her and she drove it to work and bout halfway home (aprox 40-50 miles) and it poped a code so i swung by this afternoon and pulled the code excpecting to find P0171 again but instead it was P0174..... Any Ideas why changing bank 2 O2 would clear up the Bank 1 code but not Bank 2? and any ideas what else could be causing the code? Im not off again tell next monday so She is gonna take it to my buddy's shop prolly Friday and see what he can pull then.
And Yes i changed the Driver side down stream O2.
Old 07-23-2013, 06:50 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Usually its the up streams that sense the problem, 9 times out of 10 the o2s are fine, they are reading a vacuum leak, I would look into a air leak after the maf, which includes the intake tubing, IAc line, pcv valve and rear elbow, intake gaskets
my .02
Old 07-24-2013, 07:04 PM
77mud's Avatar
77mud
77mud is offline
Not sure what the deal is with lights off code is gone. The o2 definitely needed changing since the wires were rubbed raw.
Old 03-08-2014, 08:05 AM
kdwellsr's Avatar
kdwellsr
kdwellsr is offline
I know its late after last reply but I am just now getting the P0174 code. Some abbreviations confuse me if I haven't worked there before or forgot. Can you tell me what the "IAc" is?
Old 03-09-2014, 06:06 AM
JWA's Avatar
JWA
JWA is online now
Received 1,394 Likes on 1,103 Posts
Idle Air Control.
Old 03-09-2014, 06:20 AM
kdwellsr's Avatar
kdwellsr
kdwellsr is offline
Thank You. What things happen to indicate that the IAC is bad? Should it be cleaned or replaced if suspected bad?
Old 03-17-2014, 06:48 PM
Tasteslikeink's Avatar
Tasteslikeink
Tasteslikeink is offline
Spurratic idling, rough idle, rpm jumps or drops on idle.
77mud
1997 - 2003 F150
07-24-2013 07:00 PM
Ben34
1997 - 2003 F150
02-11-2012 05:21 AM
jsavage
17
06-17-2010 03:35 PM
ScottInTexas
1997 - 2003 F150
09-07-2008 08:04 AM
cnw4621
3.8 & 4.2L V6
11-10-2005 02:48 PM
Quick Reply: 5.4 Lean code's.
