Will no start/run
Old 07-22-2013, 04:31 PM
daddy23's Avatar
daddy23
daddy23 is offline
Unhappy Will no start/run
2004 F350, 6.0 Was having problems maintaining power when coming to a stop, or letting up to turn. I replaced both the fuel filter and water/fuel seperator filter. Still did not run properly. So I pulled the water/fuel seperator to check for crud. No crud found. Now the truck will not start at all. Truck shows full on the fuel gauge. I have poured diesel into the filter well slowly to remove air in line. I have cycled engine five times before starting. Still nothing. I removed fuel lines and cycled, fuel comes out slowly, and just a little bit, shouldn't it come pouring out?
HELP!!!!!
Old 07-22-2013, 04:46 PM
senix's Avatar
senix
senix is online now
Received 1,447 Likes on 1,035 Posts
moved to the 6.0 forum
Old 07-22-2013, 05:26 PM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
You may have a fuel pump going out. There is a pressure test port at the bottom front of the filter houseing, requiers a 12mm adapter if iI remember correctly.
You should have 50 psi minimum.
Old 07-22-2013, 05:38 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
HELP!!!!!
Sounds like a fuel pump to me also. With the top off the secondary fuel filter housing it should fill VERY quickly--maybe 2 or 3 seconds max.
Old 07-22-2013, 06:53 PM
daddy23's Avatar
daddy23
daddy23 is offline
Thx- So, to remove the box, or drop the tank. I'm thinkin the box will be a lot easier.
Old 07-22-2013, 07:17 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Fuel pump is a combination unit. HFCM (Horizontal Fuel Conditioning Module) Same part the water separator filter goes in on frame rail under truck. No pump in the tank.
Old 07-22-2013, 07:50 PM
daddy23's Avatar
daddy23
daddy23 is offline
Sweet, that sounds a lot easier. THX
Old 07-22-2013, 08:09 PM
Rusty Axlerod
No problem, welcome to FTE!
Old 07-22-2013, 08:50 PM
Z-MAN's Avatar
Z-MAN
Z-MAN is offline
Check hpop psi minimum to start truck is 500psi. Don't ask me how I know is it cranking but not firing? Mine just gave up the ghost aT 137k
menze46
10-19-2019 10:33 AM
ZackF350Di
1999 to 2016 Super Duty
03-24-2017 03:36 AM
ExPACamper
49
03-31-2015 03:52 PM
dgulledge
01-04-2015 09:09 PM
chopperdaw
03-04-2007 06:22 PM
Quick Reply: Will no start/run
