Looking for engine ideas
I recently purchased a 1977 ford f250 and it had a 360 in it. We pulled the engine and the heads were cracked and the engine was shot so I decided we should buy a new one. Well now I want an engine that will give me a lot of torque and horsepower at low rpms for pulling and I am looking for suggestions
First of all, welcome to FTE!
I originally bought my '74 without an engine, and had a 429 thunderjet laying around - the rest is history
I don't know what your fabricating skills are, or what you have access to.
If you want to swap in a big block like I did, then it is going to take some decent skills and the equipment to do it.
Don't completely write off the FE engines yet, either. There are a lot of guys here that wouldn't trade their FE's for any other engine on the planet. A warmed over 390 is nothing to sneeze at, nor is a 428 FE. You said your truck originally had a 360, so any other FE will fall right into its place.
If you want to go up to a big block, you will need to either locate a big block auto trans, or figure out what to do with a manual trans (you didn't specify what you have). They make swap kits for a 429/460, but they are costly.
If you have a manual and decide you want a big block, I have all the information you need. Just PM me and I will send you more pages to read than you know what to do with.
I would strongly suggest looking for a 390 and warming it over. I had one found for my truck for $10, yes $10.. It was sold when I called the guy. That is when I decided mine was getting the thunderjet.
If its a daily drive/tow rig my nod would be to a diesel conversion. Better towing MPG, better MPG period than a big block. Not knocking big blocks I would like to have one but probably wouldn't be my daily driver either more a play truck. Lots of searching to do wither way you choose. Good luck on your project.
460 swap
"and I am looking for suggestions" ,390 stock or stroker,,all things remain the same (drive shafts,engine mounts,ujoints,radiators, original fe,,,,460 so many things change and continue to change(engine mounts,ujoints.wheel hop,drive shafts,radiators.t/c ujoints.flywheels pilot bearings,bell housings,,,just trying to save you alot of aggravation,unless your really into it. equipped with tons of brand new equipment!
<!--$img %ImageAssetImpl:/images/Cerame_Aluminum_482_1.jpg$-->
<!--$img %ImageAssetImpl:/images/May_08_Carman_482_Dyno_Engine_-_web.jpg$-->
<!--$img %ImageAssetImpl:/images/May_08_Dyno_Engines_002.jpg$-->
<!--$img %ImageAssetImpl:/images/May_08_Dyno_Engines_015.jpg$-->
<!--$img %ImageAssetImpl:/images/2008_July_24_251.JPG$-->
<!--$img %ImageAssetImpl:/images/445_EFI_Dyno_-_020208.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=365><TBODY><TR><TD bgColor=#ffff99 height=42 vAlign=top noWrap align=middle>445cid 390 Stroker - 505 horsepower with EFI
Pump gas, Edelbrock Stage X heads - POLISHED
</TD></TR></TBODY></TABLE>
<!--$img %ImageAssetImpl:/images/Dyno_Chart_-_Aluminum_482_Flat_Top_CNC_Ed_696_Solid_Roller-_web.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=345><TBODY><TR><TD bgColor=#ffff99 height=38 vAlign=top noWrap align=middle>482cid Aluminum 427 Stroker - 618 horsepower
Genesis block, CNC Edelbrock heads
<!--$img %ImageAssetImpl:/images/482_BT_FE_Dyno_-_052508.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=345><TBODY><TR><TD bgColor=#ffff99 height=38 vAlign=top noWrap align=middle>482cid 12.5:1 427 Stroker - 729 horsepower
Genesis block, Blue Thunder Stage X heads
<!--$img %ImageAssetImpl:/images/Dyno_Chart_-_431_Dish_Piston_Stage_X_SH7224_-_web.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=345><TBODY><TR><TD bgColor=#ffff99 height=39 vAlign=top noWrap align=middle>431cid Budget 390 Stroker - 428 horsepower
Edelbrock Performer intake & heads
<!--$img %ImageAssetImpl:/images/482_FE_Dyno_-_043008.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=345><TBODY><TR><TD bgColor=#ffff99 height=57 vAlign=top noWrap align=middle>482cid Street Stroker - 537 horsepower
Pump gas, Genesis block, Edelbrock Stage X
heasd heads
<!--$img %ImageAssetImpl:/images/Palma_Dyno.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=296><TBODY><TR><TD bg*************** height=289 vAlign=top noWrap><!--$emptyText$--></TD></TR></TBODY></TABLE>
<TABLE border=0 cellSpacing=0 cellPadding=0 width=259><TBODY><TR><TD bgColor=#000000 height=278 vAlign=top noWrap align=middle>
[***************]Short block assembly starting at
only $700
Complete engine assembly from
$1200
Let the Pro's build your next FE
We build more FE Fords each month
than most shops do in a year.
[/COLOR]</TD></TR></TBODY></TABLE>
<TABLE border=0 cellSpacing=0 cellPadding=0 width=226><TBODY><TR><TD bgColor=#330033 height=64 vAlign=top noWrap align=middle>[***************]CLICK HERE FOR
[/COLOR][***************]HUNDREDS OF FE [/COLOR][***************]FORD
[/COLOR][***************]PARTS[/COLOR][***************]!
[***************]Phone (248) 366-3309[/COLOR][***************] or[/COLOR][***************] (248) 931-0358
Fax (248) 438-6900
E-Mail Info@Survivalmotorsports.com
[/COLOR]
<!--$img %ImageAssetImpl:/images/Polished_EFI_445_009.jpg$-->
<!--$img %ImageAssetImpl:/images/520_FE_Dyno_011209.jpg$-->
<!--$img %ImageAssetImpl:/images/520_2x4_767HP_FE.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=376><TBODY><TR><TD bgColor=#ffff99 height=40 vAlign=top noWrap align=middle>520 cid 427 High Riser - 767 horsepower with 2x4s!!
12.5:1 Race gas, Genesis block Blue Thunder heads
<TABLE border=0 cellSpacing=0 cellPadding=0 width=389><TBODY><TR><TD bgColor=#ffff99 height=81 vAlign=top noWrap align=middle>427 cid Restoration Style 496 Horsepower
Original 427 heads unported, Original 427 block,
Stock stroke, Stock compression 12:1
Stock manifolds, Stock intake and repro carbs
<!--$img %ImageAssetImpl:/images/427_EFI_FE_2009.JPG$-->
<!--$img %ImageAssetImpl:/images/427_EFI_Dyno.jpg$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=389><TBODY><TR><TD bgColor=#ffff99 height=57 vAlign=top noWrap align=middle>429 cid All Aluminum 529 Horsepower
Independent Runner Fuel Injected
Pump gas, Pond block, Blue Thunder heads
<!--$img %ImageAssetImpl:/images/510_FE_Dyno.jpg$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=389><TBODY><TR><TD bgColor=#ffff99 height=57 vAlign=top noWrap align=middle>510 cid All Aluminum 668 Horsepower
Pump gas, Genesis block, Blue Thunder heads
Dual Plane BT Intake, 1050 Dominator
<!--$img %ImageAssetImpl:/images/510_Aluminum_FE.JPG$-->
<TABLE border=0 cellSpacing=0 cellPadding=0 width=377><TBODY><TR><TD bgColor=#ccffcc height=20 vAlign=top noWrap align=middle>Click To Watch This Engine Dyno Run on YouTube!
<!--$begin exclude$-->
heasd heads
only $700
$1200
Fax (248) 438-6900
[/COLOR]
Which did you decide? Many ideas were thrown out here. I would still suggest the 390 FE. It will drop right into place, and still give you some pretty decent power. Plus, you will be spending your money in the engine, making more power, whereas I spent my money adapting the big block into my truck. Basically it comes down to how much money you have to spend, and where you want to spend it.
MPG is a moot point.. Sorry to say it so bluntly, but its the truth.
Neither is going to give you good MPG's, but both will give you a decent service life, and gobs of power while doing it.
I expect that my 429 probably gets on average about 8 MPG, could do better on longer trips. A 390 with comparative power is going to get roughly the same MPG, although some people claim some fairly respectable numbers on stock motors. Like I said, a 390 with comparative power is going to be roughly the same.
Its not about the MILES per gallon, but rather the SMILES per gallon A big block gets a lot of smiles
Power-wise, my 429 is a 1968 model (high compression!) It makes about 360 hp, and 480 ft/lbs (at 2800 RPM! )
