front parking lights
If I understood correctly, the TS's work with NO lights on. If they were fed off the parking lights, that wouldn't be possible.
i am really confused now , they work with the lights off , so that would tell me they dont come off the switch ??? they do have a 2 filament bulb , i had a 58 that was that way when you turn the lights on the parking went off ,, i know a little different ,, i need to find a wiring diagram to start to trace ,, but you say they should work with lights on or off right
thanks guys
thanks guys
I stand corrected!
The diagram Jim posted (posted again below) only shows the turn signal/brake light side of the bulbs. This would be in addition to either of the other two diagrams, which only show the parking/brake lights.
The only wire this diagram has in common with the other two is the #18 gauge GREEN wire to the brake light switch.
The "Pilot" bulbs are the bulbs in the dash showing the signals on.
Edit: on second thought, if there is a point on the light switch that runs from the "Accessory" terminal, the signals could connect there. Mine ran straight from the key switch.
#30
