Parasitic Battery Drain
It takes about one week to the point where its on the verge of not turning over fast enough. When I was originally testing and found #14 to be the major leaker, I let it sit over night without the fuse. From 100% at the start of the test they were down to 45% in 24hrs. Im waiting to figure out the drain problem before I install my new Motorcraft batteries. The old is probably only little over 6 months old. While its running its putting out a strong charge. After its started for the first time, no problem restarting it....
I would suggest rather than rely on your charger, if you have a multimeter and know how to take an amp reading, you take one as it will give you a much better measure of your rate of discharge. Or take a voltage reading when fully discharged to 12 volts which would be 50% discharged.
No dice on the power cable. Fuse #3 (20A) does shut off the Edge display. #3 is Cigarette lighter, Data link connector. Does not drop power consumption like fuse #14 does.
When #14 is plugged in it spikes to .68A but settles down to .20A
Rv_Tech, I'm not quite sure what you wanted me to do with my multimeter reading voltage instead of using the charger??? Calculated formula maybe???
One thing you have noted is you feel the batteries may be off their game. I would have them tested or retested, if that has already been done.
I would be thinking of a draw about comparable to leaving the headlights on or something similar in terms of amp draw.
Not doubting what you are saying, just trying to double check. I work on stuff like this all the time and love electricity, so it is an interesting puzzle.
I charged both batteries to full capacity ~12.4v within 1/2hr the charger is showing 70%. Im starting to think my passenger battery is killing the driver side. I would think charging the DS battery would charge the PS at the same time...nope. DS can be 90%, switch side and it will be like 5%. I feel like im chasing gremlins....lol.
Rv tech.....you read my mind with all your followup tests since my last post. I was kind of leaning towards the lack of draw at .2 amps and possibly bad battery as well. I have not checked amp draw but my truck has sat as long as 3 weeks and not had trouble cranking. Mine is an xl so it has fewer electronics on it too.
My brother has a '99.5 his also can sit for 3-4 weeks and fire just fine....also running Optima red tops. This is my second set. My first set I suspect was doing the same thing. They covered them under warranty but I had to eat shipping to send them back since I ordered them off the 'net. These new Motorcraft Max batteries I bought at the local O'rielly's with a 36/100 month warranty so dont have to deal with shipping them again!
#29
I went threw 2 sets of red tops. I now believe they are junk battery's. they both swelled on me and my alternator was putting out 14.2v. Not to mention they wouldn't hold a charge after a couple months and when I contacted optima and told them my issue they basically told me to GFY. Not great people to deal with in my opinion. I ditched the red tops
#30
