Looking for high-end water pump
Old 07-03-2013, 07:28 AM
bkbauer1955's Avatar
bkbauer1955
bkbauer1955 is offline
Looking for options on water pump for 1956 ford 312 (in my f350) - looking for high flow, or billet, or aluminum -- any links or ideas /.?
Old 07-03-2013, 03:32 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
I'm not sure if the aluminum pumps are still available.
Try FORD Y
It will be a pump with car dimensions which will require a matching car pulley.
If it will be used primarily for drag racing or local car shows, you can try Ted Eaton for an electric version.
Eaton Balancing | www.eatonbalancing.com
A stock pump should cool a stock or even modified Y well enough. Do you have a cooling problem or simply want some bling?
Old 08-02-2013, 12:39 AM
chetspencer's Avatar
chetspencer
chetspencer is offline
I just got one from NAPA, working great. Lifetime warranty. Make sure you get the correct shaft size. 3/4" or 5/8".
Old 08-22-2013, 06:07 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Part number? High-mount fan version?
Old 08-22-2013, 07:14 AM
chetspencer
Sorry don't have it handy, but you need to make sure and check to see what size shaft you have now or the pulley won't fit.
abe
19
10-05-2017 09:11 PM
jvmcc
07-18-2016 05:40 PM
Tilleyman
11-20-2014 07:19 AM
Stephen67
06-12-2014 02:54 PM
1954F250
03-09-2006 12:38 PM
Quick Reply: Looking for high-end water pump
