1985 F250 5.8L wiring diagrams and fuse box diagram
Old 06-17-2014, 09:35 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
Originally Posted by bullnose1985
Great site Bill!! I just joined. Great additional 1985 documents. Everyone who diy ford wiring like me should join old school!
Glad I can help. It started more as a Chrysler Turbo resource, then as I got redoing my truck, and more involved with FTE, sort of morphed into a Ford resource.
Old 06-17-2014, 09:43 PM
bullnose1985's Avatar
bullnose1985
bullnose1985 is offline
Today I tried to rewire the DSII box well just the 2 wire plug coming out of the box is one red and one white wire and then at the plug they switch? I noticed that the starting relay didnt have anything hooked to the "I" terminal. So I rewired the "I" to the positive on the coil then a inline resistor the to the red wire on the DSII 2 wire plug. Once I energized the relay turning the key even off it wouldn't stop cranking.
Old 06-17-2014, 09:59 PM
85lebaront2
If you noticed on the DS-II diagram, the wires do reverse at the plug. The "I" terminal is only used on 7.5L with the hot fuel handling package. It provides priming power to the in-tank pump(s). The white with light blue dots wire is only hot in run, it goes the the red wire on the DS-II box. The red with light blue stripe they show in the diagram actually doesn't exist on a DS-II box, it would be the middle pin on the 3 pin plug. The start circuit red with light blue goes to the white DS-II wire in that plug. The resistor is between pin I1 and I2 on the ignition switch, I1 is run, I2 is start bypass. It will backfeed to the red DS-II wire, but the white wire is the critical one, it activates the cranking retard capability of the DS-II module.
The reason it won't stop cranking, you are activating the starter relay from the ignition power, however, stuck Chinese starter relays are very common.
Old 06-17-2014, 10:25 PM
bullnose1985
This whole thing started after about 4 hours of run time after I did a 3G alternator conversation. It ran great for about 4 hours, but then the ingnition would cut out at high speeds and each bank would backfire as the unburnt fuel would hit the hot exhaust pipe. It was so strong that it blew a hole in rusted muffler. After the engine would cool and it would start again. Additional information as the engine died the tachometer would jump pasted the engine rpm.
Old 06-18-2014, 07:25 AM
85lebaront2
Ok, take a close look at the charging system diagrams. The original system on these trucks is very strange. If you have an ammeter (useless at best) there is a special piece of wire that is calibrated for the shunt ammeter. The other issue, everything on the truck except the starter is actually fed from the alternator harness. Until the alternator starts charging, power flow is from the battery, through the fusible link into the alternator harness. From there it fans out through more fusible links to the inside of the cab. From what you describe, either your ignition module may be failing or voltage to the system is either too high, or more likely too low. Other issue can be, coil failing, pickup in distributor failing.
Old 06-18-2014, 10:12 AM
bullnose1985
I plan to print them out the next time I am in town. Reading them on the cell phone isn't as easy as I would had hoped. I didn't have this kind of trouble when I rewired my cj-7. The [diesel] wiring makes it about twice as much to keep track of compared to the jeep.
The "special piece of wire that is calibrated for the shunt ammeter." That you spoke of is that resistor on the engine side of the fire wall or the passenger side of the firewall?
So far I have replaced the distributor [and cap and rotor], coil, wires and have a spare DSII box.
I checked the primary and secondary resistance on the coil they were within specs. Then I plugged in a test light [an inline type that replaces the plug wire] between the coil and the distributor cap. A yellow fant spark was displayed on the test light.
What would be the best way to test those open ended wires?
Old 06-18-2014, 11:07 AM
bullnose1985
diagrams used to get constant start
these where the diagrams that I tried to rewire the DSII box.
Old 06-18-2014, 11:19 AM
bullnose1985
I just saw this post. None of the wires that I am working with have any stripes the all sold colors. The wire comming from the drivers side of the firewall bulk head grommet that once powered the DS-II is a purple wire that looks like it took some heat.
Old 06-18-2014, 08:20 PM
85lebaront2
First, don't even try to do wiring using a cell phone screen. Second, look at the charging circuit diagram, first the diesel one, then go from that to what you have now. The shunt wire is the special wire, but if in your disconnected wires on the right side you can identify a red with orange and yellow with light green those would be the ammeter wires.
The purple may have started life as red.
You might be ahead of the game if you can find a gas engine truck in a junkyard that has a good front harness and get the whole thing. It won't be fun, but it might be easier and faster for you.
Old 06-19-2014, 05:11 AM
bullnose1985
Yes using a cell phone isn't optimal that is for sure. Going to the library to print off what you guys provided me with thanks again!! That is a great Idea to take a junkyard it will take a few hours but that will be much easier in the long run.
Old 06-19-2014, 06:37 AM
bullnose1985
Any suggestions towards a group of years to look for in the junk yard? The truck is exempt from pollution control items and has none.
dose the shunted wire require the full length?
Thanks for your time, effort and help.
Old 06-19-2014, 07:20 AM
85lebaront2
Bullnose, I am pretty sure 85-86 will be pretty much the same, maybe back to 83. The older ones used a different alternator, but that part won't matter. Maybe one of the members on here with the parts CD can post the wiring harness section.
  #28
Old 10-02-2015, 10:49 AM
bullnose1985
Sorry i didn't get back to this message earlier Bill. It turned out to be a dieing DS-II module. Still messing with ol'blue. Started have some issues with wiring integrity and when the 6 port fuel tank selector valve went bad i had a discussion to make.
So i pulled the diesel harness out and am in the process of installing a 1980 ford harness in the 1985 chassis.
Trying to follow the haynes wiring diagram i ran in to a snag.
With in the key are "diesel" "option" and "GA only" could you please shed some light on what "GA only" could be?
  #29
Old 10-02-2015, 02:17 PM
85lebaront2
GA I would assume is gas, but I have never trusted a Haynes manual on wiring. They try to cover too much in a small area.
1980 harness is way different on the alternator, 1980 had the 1G (external regulator) system. I can't help you much on a 1980, my AllData only covers back to 1983 in detail, 1982 partially.
  #30
Old 10-03-2015, 10:33 AM
bullnose1985
Thanks Bill, yes i am figuring out that my haynes manual leaves much to be desired in the wiring diagram area.
I canned the 1G alternator and upgraded to a 3G alternator some time ago.
After 6 days on this project i got the engine to turn over yesterday. I still have to figure out a start run wire to tap into for the fuel pump relay and i have found a unidentified 2 wire plug under the drivers side frame rail.
Thanks again for your help and time, Jon
Quick Reply: 1985 F250 5.8L wiring diagrams and fuse box diagram
